engine was 100% good before i took it out from an e39.
noisy m52
vokietis
finished my m52 conversion,started the car and ooops,it has strange ticking/knocking noise,can't really tell where it's coming from
Could be any number of things, exhaust manifold leaking, flywheel catching on sump, something not done up properly like engine mount, exhaust rubbing on something etc etc etc
lambda sensors done up tight?
- Homo Hair
Did you remove the sump baffles?
Ticking and knocking are two very different noises.
How long had it been out of the 5 before you started again in the E30? My guess is a sticky lifter or two, common if the engine has been sat dry for a long time
vokietis
noJhonno wrote:Did you remove the sump baffles?
vokietis
well it's more like knocking,and yes it sat dry for about 12 monthsDanThe wrote:Ticking and knocking are two very different noises.
This one should be removed
vokietis
oh no
are u saying crankshaft is touching it?is it possible to remove the sump without removing engine?
I can imagine what is happening...
Not all E34 sumps have them though, only the 2 litres
If you left the pressed steel scraper plate on you wouldnt have been able to fit the sump with that baffle
vokietis
yes i did leave the plate...DanThe wrote:Not all E34 sumps have them though, only the 2 litres
You must have used a 525 sump then which doesnt have the baffle
vokietis
yes i think so,because sump fitted with no probs at all.DanThe wrote:You must have used a 525 sump then which doesnt have the baffle
vokietis
sorted thanks,crank was touching the plate due to my stupidity
- Homo Hair
vokietis wrote:sorted thanks,crank was touching the plate due to my stupidity
