What parts can I use from a E39 328 for a conversion?
Jozi
Post Sat Jun 19, 2010 6:39 pm
Following on from my other thread identifying if the engine I looked at was a 2.8....
What parts do I need or will be usefull from a e39 for a conversion?
Engine + ECU
EWS + Key
Power steering pump
Alternator
Starter?
Exhaust?
The whole car is there to get bits of.
Andy325i
Post Sat Jun 19, 2010 7:06 pm
All of the above, but only front part of the exhaust. What year is the car? Not sure if anyone has fitted an M52TU (twin vanos) engine to an E30 yet
Get it in there :D
Andy
Jozi
Post Sat Jun 19, 2010 7:11 pm
There's no use for the cat(s) and back box? Unfortunately I'm going to get stung with stricter emission standards than than pre 93 car get hence the why I'm asking.
Pretty sure it's single Vanos, there was 98 stamped on the block, same year as car, but not original engine for the car.
Andy325i
Post Sat Jun 19, 2010 7:20 pm
How do your laws work? Do you need to fit the cats? If not get them weighed in!
Jozi
Post Sat Jun 19, 2010 7:23 pm
I'm sure it's quite similar to over in the uk. pre 94 cars have to pass lower emission standards than 94 and later car, ie mine and it was a bit of a chore getting it to pass with the m42 engine (i had to get a lette stating the year of manufacture of the donor car)
Andy325i
Post Sat Jun 19, 2010 7:29 pm
So Ideally you want to keep the cats then, so they can be incorperated into the exhaust you fabricate :)
Jozi
Post Sat Jun 19, 2010 7:33 pm
Thats what I'm thinking, just to play safe!
I'm tempted to go up tomorrow for that engine, the above list is EVERYTHING I need then? He's a long way away from me
Jozi
Post Sat Jun 19, 2010 7:45 pm
Is the brake booster of any use? Calipers maybe?
Post Sat Jun 19, 2010 10:23 pm
In the UK a late E30 with an even later engine is NOT tested to the stricter emissions. There's an exemption because the body/engine combination is non standard and doesn't appear in 'the list'.
Are you sure there isn't a similar exemption in Ireland?
Post Sat Jun 19, 2010 11:13 pm
The wiring loom is no use, the alternator might be the later type with a plug in connector which is best swapped for an earlier M52 type.
The thermostat housing will need changing, alloy M50 type is best
Apart from that its pretty much just an E36 328i engine 8)
Post Sun Jun 20, 2010 9:38 am
What's the problem with the loom, Dan?
Jozi
Post Tue Jun 22, 2010 8:01 am
Would also like to know why the loom is no good?
I'm prob going to go for this engine this weekend, just to repeat myself
Engine + ECU
EWS + Key
Power steering pump
Alternator
Starter?
Exhaust (just in case I can use it)
Radiator?
