CR24v Custom M52B30 FTW. New Exhaust, New gearbox and Fan.
jmc330i
Mon Jun 07, 2010 6:22 pm
Just thought - have you got the E30 M3 5 stud? And are you running the standard M3 front calipers?
If so, those wheels wont clear the anti-rattle clip on the front caliper without a 5mm spacer, but 5mm is too thick and means the wheel wont locate on the hub, just on the wheel bolts which isnt good.
Some people say run without the clip, but I dont like that idea.
Ive got 3mm spacers (so the wheel sits on the hub) and have taken a grinder to the anti-rattle clip to gain the extra clearance needed. Its not ideal, as the extra track of the M3 suspension plus the 3mm spacer does leave the front tyre very close to the arch - again, this is on mine with a 50mm front drop and the extra weight of the S50.
James
'91 325i Sport
'93 318i touring 16v
Mon Jun 07, 2010 6:25 pm
DanThe wrote:
Jhonno wrote:205/45 or 215/40..
Get back to the VW forum Jhonno :P
:rofl:
I actually mean 225/40..
215/40 is a bit small
Mon Jun 07, 2010 6:26 pm
In fact.. 8" wide..
225/40
Dezzy
CR24v it's a lifestyle
Mon Jun 07, 2010 6:28 pm
I have M3 5 stud. I am not using M3 anti roll bar as I have a mod'd 325i bar on with complete new bushes.
I will be using WMS 4 pots once Keri finishes the kit.
Anyone know the colour and code?
Oh and I will be running 225,40x16 t1r's as seen here on my now 4 stud ATC's
Mon Jun 07, 2010 6:30 pm
You do know that the M3 runs a thinner bar as the roll bar mounting method makes it more effective for a given thickness.. Therefore you will be running a pretty stiff front roll bar now.. Might make it a bit understeery
Dezzy
Mon Jun 07, 2010 6:41 pm
Mate I am leaving the anti roll bar bolted throgh the bottom arm. I may change to complete M3 in the future but I will see how it feels as is for now.
The 5 stud isn't going on straight away. As I just want it up and running first.
Dezzy
Mon Jun 07, 2010 6:56 pm
I think I will try without the anti rattle clip and see how I go. The 4 pot kit will be ready by the time I swap anyway hopefully. If so I won't even fit the front brakes. :D
RM2186
Mon Jun 07, 2010 7:00 pm
Dez, OT mate, but can you switch some tyres over for me on 4 BBS wheels :wink:
1987 Tech1 325i Sport
Dezzy
Mon Jun 07, 2010 7:05 pm
RM2186 wrote:Dez, OT mate, but can you switch some tyres over for me on 4 BBS wheels :wink:
Aye
Mon Jun 07, 2010 7:18 pm
You could always get the outside pad machined down a bit to bring the caliper inwards
With 8 inch rims id be going for 225/45, I keep thinking I should have used them on my 7.5 Hartges, need more 'stance' innit :)
Dezzy
Mon Jun 07, 2010 7:29 pm
Nar mate. I will have the stance with ET 23 and M3 setup.
I am not a fan of big side walls.
Outside pad Dan?
Mon Jun 07, 2010 7:30 pm
DanThe wrote:You could always get the outside pad machined down a bit to bring the caliper inwards
Bit too much tyre wall for my liking..
Mon Jun 07, 2010 7:34 pm
Chromie rear arches remember, ive bought some 5mm spacers for my rear wheels in an attempt to make it look more like the front
Dezzy
Mon Jun 07, 2010 7:53 pm
Dan outside pad?
The stut leg where the caliper bolts through or the Cartier its self?
I want to leave the strut standard but I would cnsider taking 4mm off the carrier if it's safe?
Mon Jun 07, 2010 8:03 pm
No the pad friction material, if there is less material the caliper moves inwards
keri-WMS
Mon Jun 07, 2010 8:17 pm
I know what you mean - as in part-worn pads move sliding calipers away from the wheel.
That's why sometimes people buy alloys that "just fit" sliding calipers....but then DON'T when they next get new pads!!! :D
Dezzy
Mon Jun 07, 2010 8:28 pm
Ah I get you mate. I may just do that to the pads that were in then till^^^ sorts out the 4 pot option. winkeye
Mon Jun 07, 2010 9:06 pm
Would be worth giving sir keri some dimensions for your new wheels then, if they are that tight with standard calipers
Talking about calipers mine should be ready for me tomorrow, cant wait winkeye
Dezzy
Mon Jun 07, 2010 9:14 pm
DanThe wrote:Would be worth giving sir keri some dimensions for your new wheels then, if they are that tight with standard calipers
Are we talking 540 rears for the E46 disc's Dan?
keri-WMS
Mon Jun 07, 2010 11:18 pm
Not yet I'm afraid...I know nothing about the M3 kit-to-be as it's going to be a sod to get 300mm / 16" fit (but just possible I hope).
I'll be sure you guys get to see it first though!
Dezzy
Tue Jun 08, 2010 9:28 am
Keri if you want me to send a wheel closer to the time for a test fit I will?
Pics tyred up for anyone thinking of Tyres.
To me that looks :cool:
Dezzy
rob0r
Tue Jun 08, 2010 9:54 am
E38 BBS, nice! I had a set on my E28 and I have a spare set for a rainy day when I either convert an E21 or E30 to 5 stud! Keep up the good work.
Tue Jun 08, 2010 9:59 am
They look good :D
No BMW spec valves in stock mate? winkeye
Dezzy
Tue Jun 08, 2010 10:22 am
DanThe wrote:They look good :D
I have some BBS valve caps :o:
I will be using mini motorbike valves when I fit them up properly. It's stripped back off now as them Tyres are going on the 4 stud's when they are back from coating. :D
keri-WMS
Tue Jun 08, 2010 10:48 am
Dezzy wrote:Keri if you want me to send a wheel closer to the time for a test fit I will?
Cool! Shouldn't need to though, I'll be creating the PDFs for all new kits from now on. 8)
jmc330i
Tue Jun 08, 2010 11:38 am
Dezzy wrote: Image
Thats does look good. 225/40s?
I think I may struggle to get 225/40s on the rear of mine until I raise the car a little (stupid facelift arches) as Im getting a little tyre rub with my current setup under hard acceleration (205/55/15s on ET20 15x7"s). I think I may struggle on the front also. Thats another reason I havent bought any tyres yet.
keri-WMS wrote:I know nothing about the M3 kit-to-be as it's going to be a sod to get 300mm / 16" fit (but just possible I hope)
I guess using the 4-pot caliper is part of the problem, but I think that the 16x8" wheel above will fit over a 300mm disc with a sliding caliper (but with the same anti-rattle clip issues though) and the wheel will also definitely fit on the front of an E36 M3 with standard brakes (315mm).
James
'91 325i Sport
Dezzy
Tue Jun 08, 2010 12:15 pm
225,40x16 mate
They are about 6mm smaller that 205,55x15 so you should be ok unless it's the width that's an issue. As the 55's are a ballon I reckon they will be better on the car than standard size.
My 4 studs are back from coating. When I get a second I will upload the pics. 8)
Tue Jun 08, 2010 12:30 pm
You could always roll the arches James
keri-WMS
Tue Jun 08, 2010 12:31 pm
I don't know that there will be a problem yet! Clearance depends on the particular 4-pot, also some sliding calipers are huuuuge. :D
Dezzy
Tue Jun 08, 2010 12:36 pm
I would say that the M3 sliding calipers are bigger than my 4 pots. I haven't had them next to each other yet though.
Or James could double rubber the rear springs to get that little raise. On top of the spring the rubber is much smaller so use 2 bottoms?
Tue Jun 08, 2010 12:45 pm
Wheels Looked fab Dez :thumb:
Thanks for picking up the spoiler while you were at Steves :D
Dezzy
Tue Jun 08, 2010 1:11 pm
No problem Alex.
Cheers 8)
beardymat
Tue Jun 08, 2010 1:15 pm
FAO James, I have a pair of 10mm spacers which i took off Buster`s old car which fit between the rubber and the spring on the rear to lift it without the need for new springs if theyre of any use to you.
Those Ronals look good Dezzy, if i still had the sport i would have been ripping your arm off for them, E30`s look good on 16`s
Dezzy
Tue Jun 08, 2010 1:27 pm
When I am ready to move them on I don't think I will have any problem shifting them.
They look the nuts withthe Tyres on Matt. I will stick some pics up in a bit.
Thanks for letting Steve know I wanted that sunroof pannel btw. 8)
