24v airbox
Baz666
Sat May 22, 2010 3:58 am
I also went out and got the m30 airbox after reading the tread but carnt see how it fit, i think i can work out that the afm goes in side the box ? it just fixing it and the same as Monkey says it hits the tank.
back to the drewing board i really dont want a k&n filter :roll:
bimanut
Sat May 22, 2010 3:59 pm
If you look closer at the pic you can see that dan`s using a sperate header rad and not the built in header rad.If your using a built in one it wont fit.
DanThe wrote:Some pics of my old setup
Cook318IS
Sat May 22, 2010 4:03 pm
if you look at the guide i posted on the first page it should fit with the tank on the rad :?
http://wp1016621.wp027.webpack.hosteuro ... f01130.htm
And ekos fitted with the tank too
jmc330i
Sat May 22, 2010 7:01 pm
In the pics DanThe posted up, you can see the 'bendy' bit of the rubber intake boot. In the other pic (and link) from Cook, the 'bendy' bit is inside the airbox, so the airbox will be further back giving more room for the wider rad with built in expansion tank.
James
'91 325i Sport
'93 318i touring 16v
bimanut
Sat May 22, 2010 10:59 pm
:o: :)
monkey
Sun May 23, 2010 9:35 am
after more of a look at the pics that cook posted , i now have the air box fitted but no joy with the maf to throttle body pipe . i think i will be needing an e36 inlet pipe as the oil breather pipe fitting on my e34 pipe wont clear the air box
monkey
Fri May 28, 2010 8:54 pm
just got it fitted with an e36 air pipe and the air mass meter fitted inside the box , looks a bit rough but works well .
alexbaby88
Sat May 29, 2010 8:08 am
monkey wrote:Is there an airbox that will fit a 24v e30 with abs . i would like to leave the abs pump where it is if poss . tia
Here's another solution:
monkey
Sat May 29, 2010 8:18 am
alexbaby88 is that an e36 m40 box ? . i will post a pic later of my bodge up if it stops raining
monkey
Sat May 29, 2010 12:20 pm
thank you all for the help and i did get there in the end :D Image
nickso
Sat May 29, 2010 12:38 pm
well done.
what top hose are you using? looks like a better fit than mine.
'88 e30 328i M52 track bint.
monkey
Sat May 29, 2010 12:42 pm
nickso it an e34 top hose with a bit cut off end . i have been told that an e36 one fits better but i have not tried one
nickso
Sat May 29, 2010 12:50 pm
my e36 one fits like shit, but then a lot of bits on mine fit like shit. :)
