back to the drewing board i really dont want a k&n filter
24v airbox
I also went out and got the m30 airbox after reading the tread but carnt see how it fit, i think i can work out that the afm goes in side the box ? it just fixing it and the same as Monkey says it hits the tank.
if you look at the guide i posted on the first page it should fit with the tank on the rad
http://wp1016621.wp027.webpack.hosteuro ... f01130.htm
And ekos fitted with the tank too
In the pics DanThe posted up, you can see the 'bendy' bit of the rubber intake boot. In the other pic (and link) from Cook, the 'bendy' bit is inside the airbox, so the airbox will be further back giving more room for the wider rad with built in expansion tank.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
after more of a look at the pics that cook posted , i now have the air box fitted but no joy with the maf to throttle body pipe . i think i will be needing an e36 inlet pipe as the oil breather pipe fitting on my e34 pipe wont clear the air box
- alexbaby88
Here's another solution:monkey wrote:Is there an airbox that will fit a 24v e30 with abs . i would like to leave the abs pump where it is if poss . tia
