m50 info please
ross_jsy
Thu May 06, 2010 9:32 am
Ah right.
Isn't one side meant to be hex shaped due to one being in tension and the other in compression? May be wrong mind...
Thu May 06, 2010 9:35 am
No, its a myth, check the parts catalogue and you will see the mount was fitted in pairs and with a square mount depending on vehicle, the square mounts were also fitted in pairs on some cars
Baz666
Thu May 06, 2010 3:56 pm
if i brought everythnig to do the conversion is there anyone that will but it in to a car for me,
if so what sort of cost would that be.
The only reason i ask is that i might be going down a different route with the cars. :roll:
penton08
Thu May 06, 2010 5:12 pm
:wave: price depends on how much of a hurry your in, as it would be a pj!!!
Baz666
Thu May 06, 2010 8:02 pm
it dont inclued auy of the m50 engine and stuff.
town325i
Thu May 06, 2010 10:50 pm
I hope your not planning on going to the dark side as in the M30's
Thu May 06, 2010 10:56 pm
Go for it Baz, over from the Darkside to the Good side :mad:
Fri May 07, 2010 12:07 am
town325i wrote:I hope your not planning on going to the dark side as in the M30's
If he does, he is clearly a raving homo.. :roll:
town325i
Fri May 07, 2010 9:30 am
:lol: If he does Rav will be bumming him a treat :D
Fri May 07, 2010 10:21 am
Fook, you think too much 8O
town325i
Fri May 07, 2010 10:28 am
Rav i have to do something while im not working :D
Baz666
Fri May 07, 2010 11:04 am
No ladies i`m not going m30 i`m staying with the m50 Penton is talking about something completely different, in time i shell reveal all.
All can someone confirm i need the dipstick and tube from the e34 m50 ??
ross_jsy
Fri May 07, 2010 11:50 am
Yes, and the sump.
Baz666
Fri May 07, 2010 12:10 pm
Nice 1 Ross thanks :cool:
Baz666
Sun May 09, 2010 11:18 pm
can someone help me with the part number for the oil pickup i need.
Sun May 09, 2010 11:20 pm
Baz666 wrote:can someone help me with the part number for the oil pickup i need.
NO!!
Baz666
Sun May 09, 2010 11:23 pm
BITCH :roll:
Man that text you send me :rofl:
Sun May 09, 2010 11:25 pm
Now i'm defo not helping you, SLAG!
Baz666
Mon May 10, 2010 11:29 am
anyone know as i need to order asap :?
town325i
Mon May 10, 2010 5:08 pm
You need these part numbers 11411748150 11411703947 the first one is the pick up pipe and the second one is the gasket
Baz666
Mon May 10, 2010 5:18 pm
sorted dude ordered them today. thanks town
Baz666
Sat May 15, 2010 2:13 pm
I`v been told as my touring as abs i`v got to look for a air filter is there any other options other than some sort of k&n filter as i bloody hate them. but if i have to as anyone tryed the stealth air filters from Vogue Automotive ?? or should i just get a K&N. :roll:
Sat May 15, 2010 2:30 pm
Baz666 wrote:I`v been told as my touring as abs i`v got to look for a air filter is there any other options other than some sort of k&n filter as i bloody hate them. but if i have to as anyone tryed the stealth air filters from Vogue Automotive ?? or should i just get a K&N. :roll:
http://www.e30zone.net/modules.php?name ... c&t=169127
Same as I have on mine.
Baz666
Sat May 15, 2010 3:40 pm
Thanks Brian so with abs i need the m30 box better start looking for one then.
Baz666
Mon May 17, 2010 12:25 pm
right can someone give me the info on ECU`s as i`v just been told i got the wrong one and need to know which one to get. sigal vanso none ews ecu ??? i think i need.
if anyone could give me the numbers of the ecu i know what to look for.
town325i
Mon May 17, 2010 4:40 pm
What numbers has your ecu got on it?
gcs325i
Mon May 17, 2010 4:57 pm
0 261 200 413 is the ecu you need, should have a red label.
baptie0
Mon May 17, 2010 6:49 pm
shameless plug, I have a red label ecu if you are interested, pm me.
Baz666
Tue May 18, 2010 12:35 am
baptie0 wrote:shameless plug, I have a red label ecu if you are interested, pm me.
Pm`ed you fella and replyed to you in the wanted section if it`s the number i need stated in the above thread then i have it.
also if someone else can confirm that thats the number ecu i need then all`s good.
Tue May 18, 2010 8:36 am
413 with a maroon label is the correct ECU for a M50B25 with vanos.
Label colour is important - a silver labelled 413 has EWS.
Baz666
Tue May 18, 2010 11:31 am
Thanks again Guys, the silver labelled one was the one i had, i really thought it was going to be hard to find one top man baptie0 :cool:
Baz666
Thu May 20, 2010 4:28 pm
Baz666
Thu May 27, 2010 12:10 pm
With my m50 all most done could someone tell me what would the best lcd diff to use something that would give me a better performance.
Thu May 27, 2010 12:53 pm
What box are you using Baz? If its an iS box then id opt for a 3.91 with an M50B25
Baz666
Thu May 27, 2010 1:00 pm
Thanks Dan got the link fella be in later, yeah i`m useing a iS box i`v got my sport diff but was going to look for another one for better performance.
