Beemerlad's M52 Chromie
Dezzy
CR24v it's a lifestyle
Sun May 09, 2010 8:28 pm
CR24v right there. Fooking great work brother
I can't wait to get my lump in
stup86
Sun May 09, 2010 9:03 pm
Didn't know there was a difference in the number of horns between a 4 pot and 6 pot.
I'm guessing the 6 pots had dual horns???
Parts needed:
M40/M20 ignition coil with high voltage lead
gareth
Sun May 09, 2010 11:38 pm
If you're fitting the whole touring rear end on a featherweight 2 door chromie, you way with to think about brake bias. the touring rear calipers are a 35mm bore, the saloon ones are 33mm.
Not a big difference but if it's light at the rear, it could be a little lively under braking.
good progress though :D
Sun May 09, 2010 11:44 pm
Where's the M50 manifold ???
Sun May 09, 2010 11:48 pm
Good progress Lee , certainly moving faster than the touring did ! :D
Sun May 09, 2010 11:59 pm
gareth wrote:If you're fitting the whole touring rear end on a featherweight 2 door chromie, you way with to think about brake bias. the touring rear calipers are a 35mm bore, the saloon ones are 33mm.
I never had a problem with this on the red S50 E30 when i reshell it from a touring to a 2dr. I used the touring rear calipers on the 2dr.
Very good progress Lee btw!
gareth
Mon May 10, 2010 12:39 am
it did already have a rather heavy front bias with the Wilwood bakes though didn't it?
Mon May 10, 2010 9:31 am
Wilwood 4 pots coming in the future.
Rav, it has the M50 inlet manifold :)
Mon May 10, 2010 10:05 am
You feeling ok Lee??? :eek:
Mon May 10, 2010 8:03 pm
What's the score with the earth strap on the driver side engine mount? On the touring there was a little thread sticking out the o/s chassis front leg for it to connect to, but none on the chromie. Do I need to look at getting a thread tacked onto the chassis leg or should I look at getting a longer earth strap and bolting it to the subframe or somewhere near?
Dan, have you a copy of the fitting guide for the leccy fan loom as I can't remember which wires went to which pin numbers in the fuse box. Cheers bruv
Mon May 10, 2010 8:11 pm
Here you go Lee
Mon May 10, 2010 8:14 pm
Thanks Rav, but that's a wiring diagram.
I need "put the red wire to pin 17, make a brew, put the green & brown wire to pin 30" etc etc :)
Dezzy
Mon May 10, 2010 8:34 pm
I have the email saved lee I will send it in a pm in a bit once I get a shower etc.
LSD is in whoooooo!
Where was the M10 earthed?
Mon May 10, 2010 8:47 pm
Your looms wont be the same as I use different coloured wires depending on what ive got lying around, did I email it you Lee? Might be there still
I ran an earth strap under the chassis rail and bolted it to the underside, there are a few 8mm threaded holes towards the front
beardymat
Mon May 10, 2010 8:50 pm
you should be able to find something on the N/S of the engine to connect the earth up to, possibly where the power steering bottle bolts to the engine mount. I noticed this on my M3 but im going to swap the earth mount points over on my chassis legs before i paint the bay out.
Mon May 10, 2010 8:52 pm
M10 earthed on opposite side from the sump as it sticks over there miles Dezzy.
Dan, the original instructions you sent with the loom printed out, lost somewhere in the garage, I think they got wet and the ink ran. :o
johnl320
Mon May 10, 2010 8:53 pm
If you look at the chassis rail in the pic, there is a lug sticking out with a captivated nut on it, thats what I've used and it seems to work alright.
Dezzy
Mon May 10, 2010 9:00 pm
Can't you just earth it on the oppersite side?
Mon May 10, 2010 9:13 pm
Yes but ideally you want one on each side
Mon May 10, 2010 9:27 pm
gareth wrote:it did already have a rather heavy front bias with the Wilwood bakes though didn't it?
Yep, thats why i said what i said as i sold Lee some wilwoods, the same as the ones i used.
Mon May 10, 2010 9:31 pm
As I said in my earlier post, I've lost the bolts for the inlet manifold, what a clown. Went on realOEM and they are NLA, WTF! :?
Dezzy
Mon May 10, 2010 9:41 pm
M7 mate same thread as the exhaust manifold :D
town325i
Mon May 10, 2010 9:51 pm
German car makers like using odd size nuts and bolts for stuff VW are just as bad
gareth
Tue May 11, 2010 1:06 am
ahaa, gotcha :thumb:
that should work well then :)
**BANNED**
Thu May 13, 2010 12:31 pm
Be a good :idea: to run an earth lead from your o/s engine mount direct to the battery earth pole.That's what finally sorted my sensor issues out.
Youth is wasted on the young.
oldroydsr4
Fri May 14, 2010 4:05 pm
From your pics , the sump seems to sit higher than mine (good thing) what mounts are you using?
Fri May 14, 2010 4:24 pm
E28 M5 OEM mounts on the E36 arms.
I have the round mount on the passenger side and the square/ trapezius shape mount on the driver side. I was very impressed with where the sump sits, although I don't think it is any lower than on the touring where the sump still sat the correct side of the plastic under tray.
jmc330i
Fri May 14, 2010 4:41 pm
There must be some differences between S50 and M50 then or possibly pre and post facelfit??
The sump on mine sits well low, maybe an inch or more below the plastic under tray. I have to be very careful around the lanes 8O
James
'91 325i Sport
'93 318i touring 16v
oldroydsr4
Fri May 14, 2010 5:18 pm
My sump sits approximately 50mm of the road currently with a 50mm drop, it's very worrying.
I didn't do my conversion so need to find out what mounts were used, are there any other options that could have been used?
My plan is to get the sump level with the cross member and then fab a sump guard.
Fri May 14, 2010 6:09 pm
Its possible you have E34 M50 type mounts, they are too soft for my liking
jmc330i
Sat May 15, 2010 12:05 am
Im using the E28 M5 mounts as above. Mine sits around 50mm off the road, with I believe a 50mm front drop.
James
'91 325i Sport
Sat May 15, 2010 7:06 pm
Had so hoped to get more done today but mates visiting and then getting roped into shopping trips and other crap meant sod all progress.
Had drama last night with the subframe retaining plates being a cooont to get off, had to give the 4 allen bolts the good news with the angle grinder, so that took up most of yesterday evening.
Today I got the rear end down in about 30 mins, but then the visitors arrived and her indoors wanted me to go shopping, so had to take one for the team.
Tomorrow the plan is to get the fuel tank out, replace fuel pipes, all rear brake pipes, get the replacement 63ltr tank fitted and get the rear end back on it with the koni dampers and new AVO springs.
I need to get another 325 propshaft. I can't get mine to separate and have been knocking hell out of it and still can't get it to separate. Is it just the front part that is a different length on propsahfts? i.e will the rear part of the chromie (316) prop mate upto the front part of a 325 prop?
As you can see, mine took a bit of abuse in the crash, that is how the centre bearing carrier came off the car, no vandalism required
Dezzy
Sat May 15, 2010 7:20 pm
If that's the case with the props I have a front half of a 325 prop I don't need. It's yours for a few bear tokens. winkeye
Good work matey. Nearly there now :D
Sat May 15, 2010 8:17 pm
Have you slackened the collar nut on the prop? Take it all the way back and WD40 down the spline
Shopping WTF? :mad:
Sat May 15, 2010 10:11 pm
Yeah I know mate :o:
What's the crack with the wiring you did under the rear seat? Am I plug & play for the sender & the fuel pump or do I need to be sourcing any more wiring?
