Sounds NiceCook318IS wrote:Trust me, i have the correct doorcardsThey will go on when i put speakers in the parcel shelf, a previous owner has put some huge JVC speakers in the current rear doorcards
Cooks m52 316i - going S54!
Cook318IS
Oh it is
Someone has done that in my cabby rear door cards (the bit that clips out fortunatly), cut them to put the same size speaker as what goes behind the trim panel
cant see it being easy to get another blue set either
Might just have to find some plain grill speakers to fit
Dont suppose eko took the clutch apart when he had the box out? The only explanation I can think of is the diaphram spring is being pushed into the clutch plate. You could always space the slave backwards
Cook318IS
I dont know if he did actually. If the clutch stop works fine i'll be happy enough. Taking the gearbox out again wouldn't be something i'd want to do in the near future.
Cook318IS
I've just taken the car down the road and there is clutch judder now when pulling away
- Homo Hair
Jai has had exactly the same clutch issues you have! Same box, but B32, and JB Racing flywheel.. I don't get it and neither does he. To me it seems like it is being pressed too far
How bad was the judder? I get some every now and then in my snotter, but not all the time - only occasionally when cold, so it doesn't fuss me..
i get that in my IS when cold sometimes, so does my mum in her compactCook318IS wrote:I've just taken the car down the road and there is clutch judder now when pulling away
what usually causes it?
Same here but the 318ci.Alex wrote:i get that in my IS when cold sometimes, so does my mum in her compactCook318IS wrote:I've just taken the car down the road and there is clutch judder now when pulling away
Cook318IS
It's been dynoed - have a guess what it's running
210
Cook318IS
Remember it's got the m52 manifold on still and it has an induction kit
I thought you had the M50 inlet manifold?
well 200 then
well 200 then
gooner1
- Out humping Reindeer
197 ?
- Homo Hair
198
jmc330i
197.5
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
gareth
150 at the spare wheel
-193+386
stup86
189?
Parts needed:
M40/M20 ignition coil with high voltage lead
leeparkes
196
Cook318IS
Judder has completly gone again
maybe its me.
One of you is fairly close so far
I have a video and a few photos to upload and then all shall be revealed
eko
- Old timer
Cant get my head round this clutch noise at all?
Dissappears for a week or so then raises its ugly head again
Clutch wasnt inspected or removed when I retook the box out but looked in as new condition when first fitting the M52.
Paul as said on the phone I reckon just put a clutch stop under the pedal....no more a bodge then boring holes in gearboxs
Any before/after comparisons of any of the other cars on the rolling road to confirm its still pretty accurate from lat time?
Does have a good reputation though!
Chris is over the moon,at least he hasnt cost you power
Cook318IS
I think everybody who ran has actually modified their cars since the last time actually, i'll have to double check - but as i've said before this place is renown as being pretty accurate!
203bhp and 220ft/lb of torque is a nice result for a bone stock setup other than a cone filter.
Nice one
Nice one
Cook318IS
Aye! He remembered how disappointed i was last time i went with the m50. When he had this huge smile on his face and i looked at the screen it said 200bhp. another run - 201bhp, then 202 until it hit the peak of 203.2bhpE30BeemerLad wrote:203bhp and 220ft/lb of torque is a nice result for a bone stock setup other than a cone filter.
Nice one
Not bad for a £40 engine eh?
leeparkes
Good result
gareth
not bad at all
for a little engine
for a little engine
Cook318IS
there was an m30 there actually - e34 535i. tachometer stopped reading at 300k miles about 4 mots ago and it made about 218bhp iirc
gareth
M30 FTW
eko
- Old timer
Should respond well to the M50 mani swap
Much higher than expected!
gareth
that'll be the 24 posh helium filled valves!DanThe wrote:Much higher than expected!
Cook318IS
so that is why my ride height is so highgareth wrote:that'll be the 24 posh helium filled valves!DanThe wrote:Much higher than expected!
