Dezzy
- CR24v it's a lifestyle
Post
Thu May 06, 2010 7:57 pm
They are a pain to bolt up once the beams in though?
Last time I bolted them up all bolted up seamed easier that way. I am open you advice though buddy.
I am really focused on this bad boy now. Need M50B30 in my life.
Co Founder of
CR24vTM By Invitation Only. Absolutely no riff raff!!!
Post
Thu May 06, 2010 8:00 pm
Its easy to fit them after, and there is less chance of bashing/bending stuff. Leave the discs/calipers off if you struggle with the weight
Dezzy
Post
Thu May 06, 2010 8:13 pm
Ha ha.
After it is then bruv. At least I have a no holes boot lid now. New bottom arms Z3 rack all saved from the red one. This chromie will be top spec
Co Founder of
Post
Thu May 06, 2010 8:28 pm
Mate those arms look fantastic
When it comes to putting the rear end on, I'm just bolting the full shizzle up in one go.
I'm going to have to get my shit together this weekend
Dezzy
Post
Thu May 06, 2010 8:35 pm
If I had hard standing mate I would chuck it on a trolley jack and lift it up in one lump. On gravel I reckon in bits might be the easiest way.
You better pull your finger out as I am in a rush to drive this biatch!
Co Founder of
- Homo Hair
Post
Thu May 06, 2010 10:20 pm
I did all my rear end in one go as well.. But it was on a ramp
town325i
Post
Thu May 06, 2010 11:04 pm
If your going to put the arms in once the beam is fitted leave the beam fitted loose as the filler neck on the tank gets in the way of one bolt on the drivers side
putting this lot up together on your own is one big pain in the arse and its made even harder being on a gravel drive
Dezzy
Post
Fri May 07, 2010 9:57 am
E30BeemerLad wrote:It's grim up North
Where only the strong survive
Ta Dar
Fooking pain in the ar5e on gravel but we are real men up here. With gravel rashed backs
Co Founder of
town325i
Post
Fri May 07, 2010 10:11 am
Who helped you then
Dezzy
Post
Fri May 07, 2010 10:29 am
Eva (my 21month old daughter) did most of the heavy stuff.
I took more of a superviser role
Co Founder of
Post
Fri May 07, 2010 9:25 pm
so the swap is underway, Awesome
Dez, get down to B&Q and invest in some 1" thick 8x4 sheets of Ply, will be much easier on the old back when underneath, !
Post
Fri May 07, 2010 9:29 pm
my adivce if your on the drive with axle stands is to bolt it in bit by bit,
beam, diff, arms, half shafts etc. This is how i did my 2dr
why struggle?! i'd rather lots of nuts and bolts than a swearing session because its all so heavy bolted together
Post
Fri May 07, 2010 9:30 pm
Simon13 wrote:my adivce if your on the drive with axle stands is to bolt it in bit by bit,
+1 I agree Si , it's a real biatch to fit it whole...
Dezzy
Post
Fri May 07, 2010 9:52 pm
Steve I ment to do that last time but never got round to it.
I got a big box of goodies from BMW
Z3 shifter
M3 battery cover
Chrome window trim
X2 E34 steering box UJ's
Easy way to blow £250
Co Founder of
Post
Fri May 07, 2010 9:55 pm
I promise to be careful when chopping and drilling your expensive UJ's
Dezzy
Post
Fri May 07, 2010 10:03 pm
DanThe wrote:I promise to be careful when chopping and drilling your expensive UJ's
Please do. I don't want to buy them again. Robbing b4statds.
Advice taken cheers guys
Co Founder of
Dezzy
Post
Sat May 08, 2010 6:06 pm
My van on the way home tonight. If I am allowed an hour or so in the morning I should have the rear end together
Co Founder of
town325i
Post
Sat May 08, 2010 6:09 pm
Dezzy wrote:My van on the way home tonight. If I am allowed an hour or so in the morning I should have the rear end together
There is some analness in the back of that van
Looks good though i wish i could be that arsed with my touring
Dezzy
Post
Sat May 08, 2010 6:15 pm
Oh I am ill with the cleaning bug. It's a slippery slope though. You get one thing powdercoated then you can't put x on as it's not mint so that gets coated etc etc.
The sad thing is the first rainy day it will all be minging
Co Founder of
- E30 Zone Meets/Events Team
Post
Sat May 08, 2010 6:27 pm
Fookin' woss, what else is all that stuff for, if not to get dirty
Dezzy
Post
Sat May 08, 2010 6:56 pm
It's nice to see it all in that condition though. Good to know they will be good for another 24 years.
Co Founder of
Post
Sat May 08, 2010 7:02 pm
Mines is in that condition now, and will saty like that for another year or so while it's stored
Post
Sat May 08, 2010 10:16 pm
Yeah, but at least it wont be rusty old scrap like most.
Well worth going the extra distance as the stuff will last ten times longer
Dezzy
Post
Sun May 09, 2010 7:31 pm
Small steps today as the warden wanted us to spend Quakitytime as a family.
Thanks for the tips on doing the beam then trailing arms etc. Went together like butter.
Just the diff and drives shafts tomorrow and I am done with the rear.
Looks fooking sexy under there. Total rock solid too
Oh and thanks to Danthe again how cool does this look
Co Founder of
Post
Sun May 09, 2010 8:06 pm
rock on brother, you'll be swearing like a sailor getting that diff bolted up tomorrow night
Dezzy
Post
Sun May 09, 2010 8:11 pm
Nar mate done a few now.
Get the 2 bolts started on the left then using a bar (wrapped in a rag) prise the diff bracket till can get the others started. They just spring a bit that's my way anyway. It's worked for me a couple of times now. I will have the diff on and shafts in tomorrow nay bother.
Get your thead updated brother!
Co Founder of
Post
Sun May 09, 2010 8:16 pm
If that method works I may well strip my rear end and put it in bit by bit.
I've got to tidy mine up a bit more
Updated the thread, only got a little done, but the lump is in at least.
Post
Sun May 09, 2010 8:20 pm
saved the easy bit till last, only 30 kg,make sure you've not had a curry
+ a yard full of scrap turds
Dezzy
Post
Sun May 09, 2010 8:23 pm
I have done plenty mate. This one is going to be slightly more of a challenge as no trolley jack will touch the freash powdercoat.
Co Founder of
Post
Sun May 09, 2010 11:31 pm
That steering link will need painting, they rust quicker than I was led to believe
gareth
Post
Sun May 09, 2010 11:51 pm
dezzy, you forgot to powdercoat your floorpan
Post
Sun May 09, 2010 11:59 pm
gareth wrote:dezzy, you forgot to powdercoat your floorpan
He hasn't, he's really a Cowboy
Dezzy
Post
Mon May 10, 2010 12:45 am
Gareth i would love to have a shell powdercoated. Then paint ge outside as normal. That would be
Co Founder of
tomkatdo
Post
Mon May 10, 2010 7:06 am
Nice job! Pardon my ignorance but what kind of lip is that? I am in the US and just converted my big aluminum bumpers that came on pre facelift cars here to chrome ones and am looking for a lip just like that. Thanks.
