How much room for fan?
stup86
Post Sat May 01, 2010 4:45 pm
I should be ready to fit my M50 in the next few weeks.
I was wondering if anyone can tell me how much space there is between the engine and the radiator or whether this slimline fan would fit:
http://cgi.ebay.co.uk/16-Slim-Line-Radi ... 414888270d
It heigh or depth depending on which way you look at it is 62mm.
Stu
Parts needed:
M40/M20 ignition coil with high voltage lead
turk
Post Sat May 01, 2010 4:49 pm
If u get the right size u can buy a blower fan in stead of a sucker and front mount it... but if u want it behind u could probably fit it assuming u remove viscous coupling etc...
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
stup86
Post Sat May 01, 2010 4:52 pm
Viscous has already been removed.
It mentions on the eBay ad that the fan can be used to push or pull.
I was hoping that it would fit behind that rad as I want to reserve the space in front for the future :wink:
Parts needed:
turk
Post Sat May 01, 2010 4:53 pm
It will be tight... if i get a chance ill go measure the space.. what rad u using?
Sump Baffles
TrackDays
stup86
Post Sat May 01, 2010 4:56 pm
still need to get one but i've been told the 328i one is the one to go for.
This correct?
Parts needed:
Cook318IS
Post Sat May 01, 2010 4:58 pm
stup86 wrote:still need to get one but i've been told the 328i one is the one to go for.
This correct?
Theres no right or wrong fan as such. as long as it fits and works it'll be alright.
Most people (including me) have a fan between the rad and the front of the car. Mines a 16" and i doubt you would be able to fit anything much bigger than that because the motor is already nearly touching the chassis as it is.
turk
Post Sat May 01, 2010 5:02 pm
Im using a deep e36 rad, which is good and keeps me cool... I still have viscous mind.
But as Cook318Is said... as long as it works and fits ur done!
Sump Baffles
TrackDays
stup86
Post Sat May 01, 2010 5:09 pm
This correct?
So with a 328i rad, there isn't atleast 62mm clearance to the engine?
Parts needed:
Cook318IS
Post Sat May 01, 2010 5:11 pm
i haven't measured if im honest.
turk
Post Sat May 01, 2010 5:12 pm
ill have to measure... im going out in a bit so ill do it by tonight for u
Sump Baffles
TrackDays
stup86
Post Sat May 01, 2010 5:18 pm
Parts needed:
turk
Post Sat May 01, 2010 6:34 pm
Right, I reckon with a 328 rad u'll have just shy of 55mm. thats presuming u can get the thread on the water pump where the viscous mounts.
SO I reckon u'll have to front mount it... What exactly do u want the space for in the future?
Sump Baffles
TrackDays
stup86
Post Sun May 02, 2010 1:17 am
turk wrote:Right, I reckon with a 328 rad u'll have just shy of 55mm. thats presuming u can get the thread on the water pump where the viscous mounts.
I was hoping to reserve the space for an intercooler. :wink:
Parts needed:
