No pics of the AVO shizzle as I haven't bought it yet, waiting on an email back from them, so hopefully I'll get that purchased this week.
Got a bit done today, but not much in the grand scheme of things.
Took off the complete running gear, noticed the subframe looked in better order than my other one, so I pulled all the gubbins off that. I also replaced all the front brake pipes and fitted up the clio servo and E30 master cylinder - badgered Dan a few times on the phone due to the funky master cylinder on the chromie, which has a load of crap underneath it (now in the bin)
Then I had an argument getting the E36 rack fitted. The steering UJ setup is too long for the rack to fit in the holes at the rear of the tabs, so it got fitted to the front holes and had about 5mm spaced underneath it and about 4mm on top.
Had a quick play about with the wheelsto see how they will look
She's ready for the lump to go in now though. Can't really fit any more front suspension as I need my springs and also need to get some M3 eccentric bushes pressed into a spare set of lolipops.
