visual diffference in m42 and m44 is engine
koh
Post Fri Apr 16, 2010 4:03 pm
im going to look at a crashed compact tonight to see what engine its got,hopefully to use as a donor for my touring.whats the easy way to identify the difference with the engine in situ,car has been debadged and the owner isnt about so i can see the logbook,if its the right engine i cant afford to let someone else get it!
sihooker
Post Fri Apr 16, 2010 4:21 pm
That's an M44. The most obvious difference is the inlet manifold.
leeparkes
Post Fri Apr 16, 2010 5:04 pm
And another M44
Alburglar
Post Fri Apr 16, 2010 5:51 pm
will the m44 drop straight in to an e30 with an m42 lump:
Same engine mounts?
Same loom and plugs?
Plug and play ECU?
M42 - rightness! with proper 4.27 LSD
koh
Post Fri Apr 16, 2010 7:54 pm
no,by all accounts fitting the 1.9 m44 is much more of a headache,theres a thread with an explanation of the wiring differences i saw while i was reading around earlier
rix313
Post Fri Apr 16, 2010 9:01 pm
The M42's were fitted with thos manifolds too so that doesn't distinguish them.
The main way to tell is the M44 takes its crank position reading from the back of the crank (near the gearbox). The sensor is located in the N/S of the engine under the starter motor. Best way to check is to see whether or not the aux belt pulley wheel on the front has trigger teeth and whether there is a crank position sensor underneath the lower water pipe on the O/S of the engine bay.
I don't know why the M44 is more difficult to fit than the M42 from an E36, it seems to be just internet myth as I've never seen concrete proof of the problems, just 'heard' about it.
Hibsfan1875
Post Fri Apr 16, 2010 9:04 pm
is the m44 a deisel?
Pre-mature ejaculation society dinner this friday night. No dress code, just come in your pants
leeparkes
Post Fri Apr 16, 2010 9:07 pm
rix313
Post Fri Apr 16, 2010 9:10 pm
Thank you Lee :)
Hibsfan1875 wrote:is the m44 a deisel?
No, 1.9 petrol :)
