e34 525 tds pump advice
jbh
- Hartge Crew
right got a chance of a 525tds with a dodgy tank pump and the starter plays up. does anyone know.. will a petrol pump fit the tank and do the job? same for the starter?
e301988325i
inherently the engine is an M50 block with an extra piece cast on to hold the injection pump, it is possible the starters are interchangeable, compare the part numbers on gsf's website would be a good idea.
The tank pump is not the same as a petrol one and are expensive and dealer only, well at least on my E36 325 TDS.
I said:
e30topless said:
lock the wife in there
jbh
- Hartge Crew
cheers for that bud. theres a few breaking on ebay so ill ask on there and see what they price me
snakebrain
The only thing I know about E34 tds's is that you really don't want one with a dodgy fuel pump..
e301988325i
fuel injection pump specifically
I said:
fingerman
I loved my TDS but the fuel pump was on it's way out as when it got to a quarter of a tank and under it was difficult to start - but apparently this is a pretty easy fix.
The guy who bought my tds off me was from up your way - near Saltcoats/Kilmarnock and had a new pump fitted on both his tds's - pm me and I'll give you his email
Previously owned loads of old E30s, E34s, a few E36s, E32s, E39s and an E38.
Currently in a diesel Audi - miss me old E30's....
Andyboy
- Alpina Colada
The petrol lift pump will not do as the pressure is way too high.
I have a good diesel lift pump here, £40 posted.
Templ8e30
Beware of the 4th injector leaking. My 325tds has this issue.
The leak is so bad that on part throttle No4 cylinder missfires giving vibration through the driveline.
A new injector from the dealer are £220 exchange.
At least my underbody will never rust, it's had so much diesel soaked underneath it's practically greased up.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
