Another m30b35 swap
Jean
Sun Mar 28, 2010 12:41 am
Thanks, here is todays update :)
Replaced the stock a/c fan with a spal pusher fan, and replaced an old fuel hose under the car as I was starting to smell fuel.
Rear
another rear shot, with dual trunk lights
Spal fan, nice and quiet at half speed and moves LOTS of air on full speed and still quiter than the stock a/c fan.
Mounting the fogs to the valance
And the rest of the trim
Front is on, came out pretty good for a first time doing prep work. Big thanks to Pinepig for shooting the paint/clear!
2002 with it's empty bay and wiring mess....
rear view
like this shot ...
Jean
Sat Apr 24, 2010 4:35 am
Got my new targa rs in black suede to replace the old worn/faded cloth seats.
These feel much firmer than the old ones, and hopefully won't fade.
Parking lot was empty so I decided to take a few shots of the car.
Alpina99
Sat Apr 24, 2010 11:53 pm
Very nice car,
Looking forward to seeing it complete with the side skirts fitted as well,
Gone, but not forgotten !!
Jean
Tue Apr 27, 2010 3:18 am
All the way from the land down under :) hehe.
Jean
Sun May 02, 2010 10:34 am
Bilstein sport shocks have been packaged and are on the way to bilstein for re-valving to match my gc co rates.
I couldn't help myself, original Hartge 16x7.5 are on the way as well :)
Jean
Fri Jun 18, 2010 4:53 am
Got a cabrio front sway with new bushings/brackets installed over the weekend along with 3rd oil change and switched the interior a bit to give it a little contract. Perfect timing since I had to replace the door stop/break as it broke, cabrio door stop works/is the same fyi.
Rack is leaking more than usual, they all leak right? Need to get that thing swapped after I get my tires in the next few days.
Jean
Got these installed today and took a couple quick shots. Excuse the dirty car, it hasn't been washed in probably over a month lol.
Tires are falken fk-452 in 225/45 size, wheels are 16x7.5, no spacers. Center caps will be installed a little later, need to make sure they stay on correctly.
Once re-valved shocks are installed it will be lowered some more, need to get the skirts on next.
Jean
Sun Jun 20, 2010 1:50 am
Washed, replaced valve cover gasket and took some better pics :)
Next up steering rack swap, sideskirts and proper shocks, i am thinking front will come down an inch and rear maybe 1/2 or so.
I've also got a complete shadow-line trim to install, just need to order some clips first.
rear fitment
front
Sun Jun 20, 2010 12:48 pm
Nice pics, but what's that chassis for in the background, and is that a V8 nestling in it? winkeye
zaust
Zone day release
Fri Jun 25, 2010 12:16 am
Man after my own heart, Been following this on r3 too.
M30 Tech 1 Touring on gas.
jbh
Hartge Crew
Fri Jun 25, 2010 12:22 am
cracking looking car.. great colour and what a brilliant wheel choice.. they suit a black tech1 perfectly
but then I might be biased winkeye
Jean
Sun Jul 11, 2010 11:07 pm
Thanks! :)
It's been just over 4 years since the purchase date, bought her with 156k on the odo and she's got 197x now.
318is shadowline trim is on the car. Next up is expansion tank and batttery re-location, just waiting for a couple more parts to show up... oh and sideskirts lol
Before:
After:
Jean
Thu Sep 09, 2010 4:05 am
Cleaned up the engine bay a little bit. Installed the 318is blower fan cover (has less studs etc).
I need to do something about the intake next, bring it closed to the headlight and make a heatshield of some sort...
Also installed my sport seats to see if I like them or not...
Oem seats, and replaced the broken a/c/radio cover.
Side shot from the last stage to current.
Jean
Thu Sep 09, 2010 4:06 am
UPS dropped these off , re-valved shocks to my specs (weight/spring rates/shortened front bump stops).
Went ahead and installed the rears tonight, couldn't wait.
I'll get the front ones installed along with new camber plates / struts / and tall rsm's next
Jean
Modified strut housings for the re-valved bilstein sports...with e30m3 sway bar tabs..
Looking to test all of this out finally at the last autox of this season on the 26th of this month. I want to see how the suspension/rates work out, and if necessary will
send a backup set of bilstein sports to bilstein to shorten and re-valve for stiffer rates if I feel that current rates aren't stiff enough with dot r tires in the current config.
new plates and tall rear rsm's
Jean
Mon Sep 20, 2010 7:42 pm
Couple pics with suspension installed. Not too low, and stiff enough but still dd-able.
gareth
Mon Sep 20, 2010 9:41 pm
that makes me want to lick my monitor! :)
Mon Sep 20, 2010 9:44 pm
gareth wrote:that makes me want to lick my monitor! :)
this comes to mind :D
Jean
Thu Sep 30, 2010 7:21 am
So last weekend was final event (not counting Enduro) for sacramento chapter solo2, and I finally made it out to test the car out in it's new configuration. It's been almost a year since I last autocrossed it, and it was with the m10, on different suspension/tires etc.
Me and my friend/co-driver worked the group 3, trying to get an idea on what time we should shoot for in my car. Believe it or not there was a F360 out on course with 3 drivers! That's not something you see everyday! Plenty of muscle, and some really crazy B/D Mod cars! I'll post the rest of the pictures in another thread, to show some other cars :)
After a full season, we set out goal to get somewhere in the 65-60 second window. Well, our first runs were in the 65 second window and we both finished the with 61 second runs, the co-driver beat me in my own car by 0.5 seconds! :o
Car felt really good, no understeer, rotates easy, lots of grip that we just kept discovering through the day. Enough torque to still spin the tires out of the corners. Ended the day running 28psi on the v710s by looking the contact patch wear. The course had only one slalom section after the entrance, but plenty of 90 degree and even 270/360 turns! Was deff. one of the more technical layouts...
All in all very happy with the results. Next week is enduro, meaning 3 2lap practice runs on saturday and 1 5lap run on sunday. I will need to bleed the brakes for that even for sure, and possibly throw some better pads. Currently that's the weakest link on the car, other than me/co-driver getting the full potential out of the car.
Jean
Sun Oct 31, 2010 4:59 am
Morning session, Run group 1 / Work group 2.
199 or so time
Didn't catch his time, clean car!
Field with some of the cars in the group
That looks familiar! lol
Stage 3, AD/AP stuff, nice / quick gti driven by instructor / SM champ (09)
Current (2010) SM champ (10), e36m3 wearing 275s
Quick ST civic with CSP miatas in the background
Muscle
Another SM champ (for 2008 )
ST Civic and FartRarri lol
Another view of the grid
Jean
Sun Oct 31, 2010 5:02 am
GTI at the line
Civic at the line
Finish line
Coming to the finish line
Taking off
TT at the line
Civic at the finish line
TT taking off
CP car coming back
Datsun at the line
TT coming back to the finish line
240sx taking off
Datsun coming to the finish line
Jean
Sun Oct 31, 2010 5:05 am
240sx coming to the finish line
e30 at the line with co-driver
e36 m3 at the line
E30 coming through the timing gates
Jean
Sun Oct 31, 2010 5:08 am
CP car ready to go again
Me getting the camera ready for my run lol
At the start line
TRM caps melted/fell off lol
Off we go ...
Coming onto the front straight/loop section
Going for another lap, onto front straight
Little bit sideways, but not too much
And we are done
Jean
Sun Oct 31, 2010 5:21 am
video of the run
it's heart, waiting ...
shedrool83
Sun Oct 31, 2010 5:39 am
Cars beauuuuutiful.
staley_turbo
Sun Oct 31, 2010 6:20 am
Cars very nice, clean and simple. Love it!
