Spigot bearing and fan switch
mr_dink
Fri Mar 26, 2010 1:47 pm
Hi,
does anyone know what size spigot bearing I need to order for using M50B25 with m40 gearbox? A part number would be even better.
Similarly the fan switch, I seem to remember there are 2 different temps available? Does anyone know which temperature I need or a part number?
TIA
Dink
bimanut
Fri Mar 26, 2010 2:56 pm
For the spigot bearing you need to measure the input shaft on the M40 box.(i think its 15mm,but not 100% sure)
Just tell BM that you need a bearing for an M50 engine and tell them the size of the shaft.
As for the temp switch i dont know.
Cook318IS
Fri Mar 26, 2010 2:58 pm
you will need an m40 spigot bearing. As for the temperature switch - what thermostat do you have? 88 degree one i presume?
bimanut
Fri Mar 26, 2010 3:01 pm
You sure about the M40 spigot cuz i used an M50 one and it dropped in sound
Cook318IS
Fri Mar 26, 2010 3:06 pm
its what i have on my non vanos m50 with 316i m40 box
mr_dink
Fri Mar 26, 2010 3:09 pm
Haven't looked at the thermostat yet was going to order a new 88 degree one with the alloy housing.
My M50 was a manual out a 1992 e34. Anyone know if the spigot bearing in it will be suitable?
bimanut
Fri Mar 26, 2010 3:10 pm
You must be able to use either then.
http://www.e30zone.net/modules.php?name ... c&t=159997
mr_dink
Fri Mar 26, 2010 3:15 pm
bimanut wrote:You must be able to use either then.
So was the input shaft on your M40 box 15mm?
mr_dink
Fri Mar 26, 2010 3:23 pm
Is the spigot bearing the 'grooved ball bearing' that is listed but not pictured on this diagram?
15x32x10mm - is that 15mm internal dia 32mm external 10mm depth?
Fri Mar 26, 2010 3:38 pm
I used a m20 spigott bearing with the m42 gearbox on my M52 conversion, using M20 flywheel & clutch.
mr_dink
Fri Mar 26, 2010 3:42 pm
E30BeemerLad wrote:I used a m20 spigott bearing with the m42 gearbox on my M52 conversion, using M20 flywheel & clutch.
:mad: Is that a 12mm spigot then?? Think I'll just have to measure my input shaft!
Cook318IS
Fri Mar 26, 2010 4:03 pm
Go to bmw with your vin / numberplate of your e30 (i presume you are doing it to the e30 that came with the m40 box?) and ask for a spigot bearing for that car. Thats what i did because bmwfans.info lists two different shaft sizes.
I'd definately change the thermostat to an 88 degree one, it makes a great difference to the running temperatures. Your m50 should already have an ally thermostat housing though :? If you use the 88 degree thermostat and are using a twin speed fan you will need a 81/88 degree twin temperature sensor iirc.
mr_dink
Fri Mar 26, 2010 4:14 pm
Cook318IS wrote:Go to bmw with your vin / numberplate of your e30 (i presume you are doing it to the e30 that came with the m40 box?) and ask for a spigot bearing for that car. Thats what i did because bmwfans.info lists two different shaft sizes.
Thanks, I may have an alloy stat housing already, the engine is in my mate's lockup at the moment so can't be too sure!
mr_dink
Tue Mar 30, 2010 10:16 pm
Right, after some further research about spigot bearings I've determined that -
External diameter is the same on m20/m40/m5x @ 32mm
m20 and m40 boxes have a 12mm input shaft
m50 boxes have a 15mm input shaft.
So I've ordered a 12mm spigot part no 11211709681.
Does anyone have part numbers for the 88 degree thermostat and the 81/88 fan switch?
Thanks.
wess
Wed Mar 31, 2010 3:58 pm
88 degree stat 11537511580
80/88 degree switch 61318361787
