just another m30 swap
charlE30
Post Wed Feb 10, 2010 3:00 pm
BMW E30 324d washer bottle fit's in the battery tray and when I got mine was around £10 posted from cotswolds... The photo below makes it look a bit wierd but it bolts in well and has two pumps so you can still have intensive wash
Good to see another M30 being born :D
BMW F31 335d xdrive
shedrool83
Post Sat Feb 13, 2010 5:45 pm
Another wee bit done on the m30 today.
The lpg inlet manifold was removed and will be replaced with a standard one as i wont be using the lpg now.
I gave the new inlet and rocker cover a coat of paint while they were off.
Hopefully get it back together tomorrow then its just the engine loom,rocker gasket,sump gasket,waterpump and thermostat to do.
I'm on the look out for a output flange from an m20 gearbox if anybody has one.
gareth
Post Sat Feb 13, 2010 11:58 pm
gareth wrote:if you decide not to use the sequential LPG kit, let me know, i may be tempted to have it off you if i have the money at the time. winkeye
shedrool83
Post Sun Feb 14, 2010 6:20 am
Gareth everything is there but as said before the loom has been chopped here and there as it was wired through everything it could have been in the donor.
It will also have the m30 inlet c/w the engine loom.
I was going to get some pics of it today and drop you a pm as i remembered you saying you might be interested in it.
gareth
Post Sun Feb 14, 2010 10:54 am
cool, keep me posted :D
shedrool83
Post Sun Feb 14, 2010 12:16 pm
gareth wrote:cool, keep me posted :D
Will do bud
Baddave has also said it maybe possible for him to drop it off to you should you take it.
gareth
Post Mon Feb 15, 2010 12:18 am
Will do bud
cool :) maybe meet up when i'm roaming... it's not far off now :D
BadDave
Post Mon Feb 15, 2010 6:51 pm
gareth wrote:
Will do bud
Meeting you on roam anyway bud, to drop off that M3 diff you said you'd rebuild gratis for me :D
shedrool83
Post Mon Feb 15, 2010 10:33 pm
More done tonight woohoo
The inlet is back on (nightmare it was cramp in fingers and hands :( )
rocker gaskets and water pump also done.
So next will be the thermostat which i forgot to get the dreaded sump gasket and the engine loom which i should have tomorrow from oldie woohoo
Does anybody know were the small vaccum from under the inlet manifold go's?There are 2 one from the fpr and i cant remember where the other one go's to :-/ .
Gareth i took a couple of pics of the lpg but my phone aint the best.
Few more pics from crap camera phone.
90l tank
inlet
leeparkes
Post Mon Feb 15, 2010 10:51 pm
Goes here fella :wink:
shedrool83
Post Mon Feb 15, 2010 11:13 pm
Thanks Lee
gareth
Post Tue Feb 16, 2010 12:10 am
ooh, that does look a like a whole load of wiring fun 8O :D
Dave, you are indeed a cheeky fecker :P
shedrool83
Post Tue Feb 16, 2010 7:19 am
Gareth the engine loom is still connect and the cover isnt on the injector loom so looks worse than it is really.
zaust
Zone day release
Post Tue Feb 16, 2010 9:42 am
On both the inlet mainis i have off the car and the one in mine in mine, One goes to the fpr and the other Back into the afm boot and there is a third under neath that should be blocked.
M30 Tech 1 Touring on gas.
shedrool83
Post Sun Feb 21, 2010 11:58 am
leeparkes wrote:Goes here fella :wink:
Had a look at it yesterday and i dont have a connection on the pipe from the rocker cover for it :cry: Didnt see one on the boot either.
gareth
Post Sun Feb 21, 2010 12:39 pm
those pipes do like to go hard and crack. is yours a cut length of pipe or a moulded part? it should be a moulded bit in a similar material to the inlet boots etc.
shedrool83
Post Sun Feb 21, 2010 3:30 pm
I'll have another look at it Gareth the next time i at the shed.
shedrool83
Post Fri Feb 26, 2010 8:04 pm
Had another look and the connection is there for it but the hose is plit so will need a new one anyway along with a tb to afm boot.
gareth
Post Sat Feb 27, 2010 1:59 am
mine needed new ones too. they're a lot nicer to use when they're soft and rubbery. mine turned into brittle plastic! :lol:
shedrool83
Post Mon Mar 08, 2010 6:27 pm
Trying to swap pins 3 and 8 on the m30 loom but how do you get them out the plug?
DRIFTBOY
Post Mon Mar 08, 2010 6:31 pm
I cut the wires a couple of inches down from the plug and re-soldered them.
The rubber boot covers the join up too. :)
shedrool83
Post Mon Mar 08, 2010 6:35 pm
DRIFTBOY wrote:I cut the wires a couple of inches down from the plug and re-soldered them.
Was going to do the same but i'm sure i read you can just pull the pins and swap them.
Just cant find the post now :cry:
Post Mon Mar 08, 2010 7:31 pm
You need the tool to pull out the pins, better off doing it the way as above, cut,solder and heatshrink. :cool:
shedrool83
Post Mon Mar 08, 2010 7:51 pm
Seems like a plan .I did find gareths post about turning the locking ring at the back of the plug but i still cant get them out.
shedrool83
Post Sun Mar 21, 2010 7:13 pm
Right made a wee bit of progress today.
325 Engines is out and leccy fan in.
Hit a few snags .I need to get a deep 30mm socket to remove the gearbox flange and the air con fan off the donor was goosed so had to dip into my mate stash again.
Hopefully get a socket for the flange tomorrow(Lee what did you use?).Still have to bore and re tap one manifold stud and cut in the tee on the hose before i can attempt to get the engine in but hopefully get it in by Tuesday.
leeparkes
Post Sun Mar 21, 2010 11:33 pm
I got mine from halfrauds, about £6 i think
Good luck with holding the flange still while you undo the nut :D my M20 one came off without a struggle but the M30 one i had to bolt a bar to the flange then get my fat neighbour to hold the gearbox down while i undone the nut
Remember theres a securing plate around the nut too
Progress at last :D
shedrool83
Post Tue Mar 23, 2010 10:36 pm
Needing a few questions answered .(lee / Rav)
1..Do i need the knuckle off the m20 gearbox and if i do have do i remove it.
2.. Is it the flange i heat Rav to turn the flange 90 degrees as it looks welded.
3..How much atf does the gearbox take.
4 Is it ok to use the m20 clutch slave
tia
staley_turbo
Post Tue Mar 23, 2010 10:37 pm
Yes it is.
gareth
Post Tue Mar 23, 2010 10:53 pm
they're the same AFAIK, though there are two different widths i've seen so it'll have to match your linkage. if you need to remove it, slide the clip back up the knuckle and push the pin out. it'll then slide off the shaft
yes
shedrool83
Post Tue Mar 23, 2010 10:55 pm
yes
Yip i have the wrong one on the m30 for my linkage then so i will have to change it :cry:
leeparkes
Post Tue Mar 23, 2010 11:03 pm
shedrool83 wrote:Needing a few questions answered .(lee / Rav)
tia
1, i swaped the knuckles over but not sure if its nessasary
2, i didnt touch my flange but you can rotate them to give more clearance, if your messing with the manifold id cut & shut it to get it closer to the block to get it E36 rack ready
3, dont know
4, M20 clutch slave works fine although i remember someone sticking with the M30 one to make the clutch pedal softer :gay:
Post Wed Mar 24, 2010 12:02 am
tia
Sorry for the late reply, but
1. Yes
2. Yes
3. Don't know
4. Yes, I am atm.
shedrool83
Post Wed Mar 24, 2010 7:06 am
tia
1. Yes
2. Yes
3. Don't know
4. Yes, I am atm.
Did your flange have what looks like a weld around it?
I tried heating it last night but it wouldnt budge.
charlE30
Post Wed Mar 24, 2010 7:34 am
Good to see some progress :D
If your talking about the flange on the exhaust manifold it is welded and the only way to rotate it is to cut and re-weld and as Lee has stated get it as closs to the block as poss so you can do a rack upgrade later. If your happy with the E30 steering you don't actually need to touch the manifold, just grind a corner off the flange and it all fits fit.
M30B35 getrag 260 takes 1.25lt of ATF oil
Did your doner have aircon? if it did do you still have the compressor mounting brackets? I'm going to be swapping my M30 across into my tourer which has aircon and I'd like to retain the use of it but don't have the bracket.
Charlie
BMW F31 335d xdrive
Post Wed Mar 24, 2010 9:01 am
My downpipes wrer heater ans twisted, they weren't welded :mad:
