Fitting m3 windscreen into non m3
ross_jsy
after a heated front screen and the only one i can find is for an m3. reading way back in the motorsport section people are saying it will either fit straight in or fit with certain parts.
anybody able to clear this up?
yetti24
i fitted a normal e30 screen into an e30 m3, so i would imagine the other way round would work, and that was using a mondeo or fiesta rubber because on the e30 m3 it is bonded
Surely an E30 screen rubber would have been better?
You will need the seal/trim to fit an M3 screen, expensive if it ever gets cracked though...
UweM3
There are some real opposite messages about this.
I once tried to fit an E30 windscreen to my M3 and it didn't fit at all. Not a chance.
yetti24, what screen was it? from chrome bumper model or plastic bumper?
as far as I know you need to grind the mastic face away from the M3 shell to be able to fit the E30 rubber seal and screen.
yetti24
the screen i fitted was from a chrome bumper 320i coupe, the m3 had had a new scuttle fitted and it was bare metal (apart from paint) around where the windscreen fits in, i would have liked to of used an e30 m3 seal but i could not get hold of one at that time, so a friend who works for a windscreen company came round and we tried all different seals to see what would be nearest to factory look
beardymat
- Location: sheffield, city of steel, and rust apparently
doesnt the M3 have a fatter windscreen flange for the glue to sit on? Also im led to believe that the M3 screen has a black band on the edge of the screen all the way round to stop the glue degrading under sunlight.
just realised the op is going the other way round, not too sure if the apperature is the same size externally but if it is you should be able to fit it with a standard e30 seal.
So you had a standard E30 screen bonded in yetti?
Mat they do have a black band around the edge and the aperture is the same
ross_jsy
as long as the apperature is the same then it shouldnt be a problem im hoping.
ill email the company for dimentions and have a look
beardymat
just realised the M3 screen may be bigger as it only has a thin trim round the outside edge which will make it too big to fit with a standard seal, let us know what you find as this may be relevant to my latest project.
Kos
demlots has an M3 screne in his IS,
iirc, you need the m3's screen trim, and the inner A pillar covers are different
ross_jsy
ill just need the screen trim since the interior is stripped.
why do i get a feeling im gonna be shafted by the m tax here
If the trim is anything like the price of an E34 trim you might change your mind
ross_jsy
realoem sats its around $41.
have to see what the local stealer wants though, as half the time the prices have no relation to those on real oem
DaveD
- E30Zone Wiki Specialist
ross_jsy
had seen that. guess there just wasn't enough interest to make it feasable.
what happened to xlr race parts? go bust?
