Cooks m52 316i - going S54!
Post Sun Mar 14, 2010 8:34 pm
Dude, drop penton08 on here a PM, he is working at BBB and they have some cheap springs that would do the trick.. Or chop a coil off the front springs for now..
eko
Old timer
Post Sun Mar 14, 2010 8:56 pm
Paul,how low you wanna go with it?
Tims springs are coming off this week.........you brave enough?? winkeye
Cook318IS
Post Sun Mar 14, 2010 8:58 pm
did he change his from the 60/40's? i was only planning on a 40mm drop max becuase of the sump and i reckon i wont get the car on the driveway with anything lower :(
eko
Old timer
Post Sun Mar 14, 2010 9:00 pm
Cook318IS wrote:did he change his from the 60/40's? i was only planning on a 40mm drop max becuase of the sump and i reckon i wont get the car on the driveway with anything lower :(
From memory he bought his expecting 60/40 drop but in reality......well come on youve seen it 8O
Cook318IS
Post Sun Mar 14, 2010 9:01 pm
More like 4 pot 80mm drop tbh! I'll give it a miss bud, waay to low for me. Although, having the lighter m52 would mean i get more sleeper points becuase the ride height will be even higher won't it? :chuckle:
eko
Old timer
Post Sun Mar 14, 2010 9:12 pm
M52 isnt that much lighter than the M50 though is it?
Few kg`s maybe?
Post Sun Mar 14, 2010 9:15 pm
It is about 20kgs lighter iirc
eko
Old timer
Post Sun Mar 14, 2010 9:19 pm
Jhonno wrote:It is about 20kgs lighter iirc
Cant see it having a dramatic difference on the ride height,what you think?
Although his car does already sit like a Land Rover 90 so not sure it can get any worse :snigger:
Paul stop being tight and get some springs ordered and they can be fitted while the car is already jacked up.
Dezzy
CR24v it's a lifestyle
Post Sun Mar 14, 2010 9:27 pm
I have read that with 6 pot springs with M52 you get understeer. When changed for IS springs it was much better.
Don't think ride height would be altered much. :D
Post Sun Mar 14, 2010 9:31 pm
I think it makes a difference, albeit maybe not huge..
H&R cupkit springs! :cool:
Dezzy
Post Sun Mar 14, 2010 9:37 pm
If it were mine I would go for 50/35 4 pot springs and a sump guard. Facelifts need a drop IMO. 8)
Cook318IS
Post Sun Mar 14, 2010 9:40 pm
Its all in the sleeper spec, honest!
At the moment i'd settle for some iS springs. I've got some unknown 6pot springs in a box in the attic, could be mtech but probably not knowing my normal luck! I can't afford h&r springs atm which is what i want really (with b8 shocks obviously). I was going to go for 40mm allround, my standard iS used to clip the front splitter getting onto the driveway!
I've just done some calculations using the 328i gearbox ratios with a 3.64 final drive and at 70mph it should be revving at 3,200prm where on the standard diff it would be about 3k. It doesnt seem too bad so i might stick with the 3.64 for a bit longer than expected :chuckle:
Post Sun Mar 14, 2010 9:46 pm
3.2k is where mine does 70 with a 3.25 diff.. I would check your math :wink:
Cook318IS
:? i used an online calculator if im fair :o: i'll double check it :?
Dezzy
Post Sun Mar 14, 2010 9:47 pm
Cook318IS wrote:Its all in the sleeper spec, honest!
I think that might be slightly wrong mate.
I have been told that my 3.64 LSD would loose the use of 1st altogether. Might be wrong though 8)
Post Sun Mar 14, 2010 9:49 pm
Cook318IS wrote::? i used an online calculator if im fair :o: i'll double check it :?
1:1 5th..
I know you've done something wrong there
Cook318IS
Post Sun Mar 14, 2010 9:51 pm
1:1 5th..
I remembered the wrong value :chuckle: i did try it with the 3.25 and it came out at 3.2krpm. Just tried it again and its 3.6krpm with a 3.64 diff.
:o:
it would only be using a 3.64 diff until i can afford to buy a 3.25 lsd tbh.
Cook318IS
Post Fri Mar 19, 2010 7:18 pm
Nice few words in this months total bmw magazine in the work in progress section on my car :D I was so excited when B15NAC texted me to tell me :D :D
monkey
Post Sat Mar 20, 2010 6:47 pm
just seen the mag well done , whens the full feature ? :D
Andy325i
Post Sat Mar 20, 2010 6:52 pm
Daf318is wrote:Looking good :cool: 24valves rule :thumb:
When you drive them they are worth all the effort and money :D
Here here! Lot of time getting there but the grin factor makes it all worth while :)
Cook318IS
Post Sat Mar 20, 2010 8:25 pm
monkey wrote:just seen the mag well done , whens the full feature ? :D
Cheers bud :D I didn't even know that i had won the meguiars kit, but i suppose the mag has only been out since yesterday. Time will tell i guess!
Cook318IS
Post Tue Mar 23, 2010 9:16 pm
I don't suppose anybody could confirm the amount of oil a m52 gearbox takes?
Post Tue Mar 23, 2010 9:31 pm
Its about 1 litre mate
Cook318IS
Post Tue Mar 23, 2010 9:32 pm
cheers dan :D :thumb:
Post Wed Mar 24, 2010 10:05 am
I thought it was 1.7? :?
oldroydsr4
Post Wed Mar 24, 2010 5:38 pm
I'm currently running a 3.46 LSD in my m50 and at 80mph it's about 4k, personally I think a 3.64 is too short, unless your sprinting. :D
Post Wed Mar 24, 2010 6:02 pm
Jhonno wrote:I thought it was 1.7? :?
Diff is 1.7 litres IIRC Jhonno
Cook318IS
Post Wed Mar 24, 2010 6:10 pm
I've got some leftover oil from when the NV engine went in, so i've got plenty either way. i thought the diff was about 1.7 litres too.
The 3.64 diff is only a stop gap until i get a 3.25lsd which hopefully won't be too long.
Cook318IS
Post Tue Mar 30, 2010 8:29 pm
Not alot to report about the engine conversion side. The recent shite weather has meant that its been slow progress.
But! For some reason completely unknown to me my mum has bought me a new stereo. The one i've got at the moment is a VERY good unit i've had for about 3-4 years. Its getting abit worn and i fancy a new one really. I've had my eyes on a pioneer deh-p77mp ever since the previous owner of the 318iS i had, had one it the car (which he kept :( ) My mum has bought one a mint example of one! (im still trying to work out why!)These stereos are one of the best pioneer have made and they are a step closer to oem than my current one :chuckle:
Old pioneer unit
And a couple of pictures from the internet of the new stereo (i cba to photograph it yet)
Cook318IS
Post Wed Mar 31, 2010 8:35 pm
I put the stereo in tonight - its gorgeous! The sound quality is amazing, even with the original 19 odd year old speakers! Im certain the stereo is new even though i bought it used. None of the stickers on the radio "body" have been damaged from the cage and it still has quality stickers on it, the loom is unused and so it the cage! Its packed with features too which is excellent for an old stereo! It might be a refurbished unit mind, but it still looks mint! :D
oomz1975
Post Wed Mar 31, 2010 10:31 pm
Love this thread, nicely done.
I like the head unit too.
Cook318IS
Post Fri Apr 02, 2010 4:45 pm
Cheers oomz!
Today the donor car started to get undressed. In the words of eko - "it is the rustiest e36 i have ever seen". The spare wheels is almost mint and the airfilter is a k+n panel filter by the looks of it!
Not far wrong either tbh...
Windscreen pillar
Behind the sideskirt
Anybody know what these dampers are? They don't look standard! We'll probably have a good look tommorow anyway.
VGC spare wheel
the state of the front end atm.
And during the day we were visted by a "500bhp" s13 200sx drift car
Post Fri Apr 02, 2010 5:01 pm
Aaarh, plenty of barnacles me sees
Thats rotten 8O
i suppose the e36 is starting to fall into the rusty category, but i assume thats a late model :eek:
Cook318IS
Post Fri Apr 02, 2010 5:03 pm
E30BeemerLad wrote:Aaarh, plenty of barnacles me sees
:lol:
On one of the rear arches it actually looks like its been repaired with putty!
This is a n reg model alex. Like eko said - doesn't bare thinking about how it would fair in an accident. Imagine if its been like that for a few mot's....
