e36 engine mounting arms
As i look at the exhaust side of my engine (m50) there are 6 holes like this rear : : : Front which ones do i use when ptting on the e36alloy engine arm?
Also which holes are used on the inlet side of the engine for the mounting rm? cheers
Any pics would be great, cheers
stup86
Boomer
Do your engine arms look the same as mine? I got mine from a scrapyard a few days ago and just checking I did get the right ones.
Exhaust side arm:
Inlet side arm:
Stu
Exhaust side arm:
Inlet side arm:
Stu
Parts needed:
M40/M20 ignition coil with high voltage lead
Next problem, what do i do with the dip stick tube as it now completely prevents me fitting the inlet-side mount.
Also i have fitted the exhaust-side mount and quickly measured it and it looks like it has to be ifitted in the rear holes afterall!
stup86
I trying to fit the inlet side mount and one of the bolts won't go it.
The one i'm talking about is the bottom right hole in the picture below.
It's like it doesn't have a thread? Is this normal?
Stu
Stu
Parts needed:
stup86
Well, it wasn't playing ball put it that way.DanThe wrote:You should be using all 4, no reason why it cant be tapped out again, unless you have 'animaled' a bolt into it?
I'll try again tomorrow and see how things go.
Parts needed:
