e36 engine mounting arms
booomer
Thu Mar 11, 2010 7:13 pm
As i look at the exhaust side of my engine (m50) there are 6 holes like this rear : : : Front which ones do i use when ptting on the e36alloy engine arm?
Also which holes are used on the inlet side of the engine for the mounting rm? cheers
Any pics would be great, cheers
Thu Mar 11, 2010 7:20 pm
Front, the mount on the inlet side will only bolt into one place
booomer
Thu Mar 11, 2010 7:22 pm
so front on the inlet side, what about the exhaust side?
Thu Mar 11, 2010 7:29 pm
Front on the exhaust side, the inlet side will only bolt into one position 8)
booomer
Thu Mar 11, 2010 7:32 pm
Ah cool, without going out into the cold, is the position of the inlet side arm the same position as the arm that came off the car? or does it sit further back.
Sorry its just that i havent got it in front of me
Thu Mar 11, 2010 7:55 pm
You can see the 4 holes where the mount was removed on this engine
booomer
Thu Mar 11, 2010 7:56 pm
Cheers Dan
stup86
Fri Mar 12, 2010 6:50 am
Boomer
Do your engine arms look the same as mine? I got mine from a scrapyard a few days ago and just checking I did get the right ones.
Exhaust side arm:
Inlet side arm:
Stu
Parts needed:
M40/M20 ignition coil with high voltage lead
ross_jsy
Fri Mar 12, 2010 10:42 am
look like the right ones yes 8)
stup86
Fri Mar 12, 2010 1:00 pm
Great.
I've cleaned them all up now, so glad they're right!
Stu
Parts needed:
booomer
Fri Mar 19, 2010 8:35 pm
Next problem, what do i do with the dip stick tube as it now completely prevents me fitting the inlet-side mount.
Also i have fitted the exhaust-side mount and quickly measured it and it looks like it has to be ifitted in the rear holes afterall!
Fri Mar 19, 2010 8:46 pm
The arms fit roughly in the middle of the engine, looking at the picture I posted above you can see the mount arm fixing holes either side of the coolant hose
stup86
Fri Apr 02, 2010 6:46 pm
I trying to fit the inlet side mount and one of the bolts won't go it.
The one i'm talking about is the bottom right hole in the picture below.
It's like it doesn't have a thread? Is this normal?
Stu
Parts needed:
Fri Apr 02, 2010 6:50 pm
It does have a thread, but its full of rust. You need to run a tap down it
stup86
Fri Apr 02, 2010 6:56 pm
Great, thanks.
Parts needed:
stup86
Fri Apr 02, 2010 7:32 pm
Will it hold ok with 3? The hole is wanked good and proper!
Parts needed:
Fri Apr 02, 2010 9:24 pm
You should be using all 4, no reason why it cant be tapped out again, unless you have 'animaled' a bolt into it? :)
stup86
Fri Apr 02, 2010 10:27 pm
DanThe wrote:You should be using all 4, no reason why it cant be tapped out again, unless you have 'animaled' a bolt into it? :)
Well, it wasn't playing ball put it that way.
I'll try again tomorrow and see how things go.
Parts needed:
Fri Apr 02, 2010 10:45 pm
Dig the crap out with a small screwdriver first
