Demlots new mod!
Demlotcrew
Sat May 30, 2009 12:30 am
Had to do it.
Ap CP5200 with 315x28 disks - All custom made by BG developments, the bell incorporates a 15mm spacer. The disk is very close to the tie rod but nothing critical. I gave BG a strut a wheel and asked them to fit the best size of disk for my 16" wheels.
What a difference! :D
Yes i know my hartges need a refurb but one thing at a time!
Jon_Bmw
Dangerous when thinking
Sat May 30, 2009 12:35 am
Nice andrew.
How much do the discs come in at when you need to change them?
Demlotcrew
Sat May 30, 2009 12:36 am
The rotors are £220 + vat each and they have a wear depth of 1mm :eek:
Jon_Bmw
Sat May 30, 2009 12:40 am
Ouch. :o Is it 1mm because you'll go straight 'through' the grooved sections.
Sat May 30, 2009 12:41 am
1MM :clin: :clin: :clin: :clin:
Demlotcrew
Sat May 30, 2009 12:42 am
Jon, i think it has something to do with the efficiency of the disk dropping off really badly when 'some' of the mass has worn away.
Im running DS2500 with these because they are kind to disks unlike Pagid, mintex etc.
gareth
Sat May 30, 2009 12:44 am
nice :D
do they specifically use lucozade as brake fluid? winkeye
how's the arch clearance with the new combined offset? a the bells 15mm thick or 15mm thicker than the standard discs?
Demlotcrew
Sat May 30, 2009 12:54 am
Hi Gareth,
The bells are 7mm + 15mm = 22mm over all. No problem with arch clearances (BG made me a spacer and sent it over so i could bolt everything up and check for issues before they machined the brackets and bells)
Over all this kit weighs about a third of the audi TT/300mm.de kit and its instantaneously noticeable when driving the car. Im actually shocked about the difference (lighter/more responsive steering and very little locking up when braking really hard)
A
gareth
Sat May 30, 2009 1:06 am
sounds like you've found someone out there who values customer service 8O can't fault letting you have spacers for a dummy build
i guess this wasn't cheap? :eek:
BadDave
Sat May 30, 2009 1:17 am
Happy with the end result Andrew??
Has it been well worth the wait?
Kit looks good BTW
Any chance you could PM me BGcontact details please.
Those mounting bells looks just like what i'm after for my new kit.
Demlotcrew
Sat May 30, 2009 1:19 am
Nah not cheap! But well worth it, a kit like this will never really loose its 'value'
I would highly recommend David at BG hes a very nice guy and did an amazing job at getting these rotors/callipers to fit under my wheels. Its not an easy setup, they had to make several mockups and build the kits up, then where they could they machined down the brackets/bells and built the kit up again and they did this until there was mm's clearance everywhere! I actually think that the finished 'spacer' was 13mm not 15mm but i need to wait and see the drawings. Im off to the ring tonight so i had to get these on!
Demlotcrew
Sat May 30, 2009 1:23 am
BadDave wrote:Happy with the end result Andrew??
Kit looks good BTW
Well worth the wait! The quality of the finish and the fit is just amazing im more than pleased + im not easily impressed!
Their details are here;
http://www.bgdevelopments.co.uk/
BadDave
Sat May 30, 2009 1:31 am
Thanks Andrew.
Much appreciated :thumb:
Oatcake
Sat May 30, 2009 8:18 pm
:sleep:
Sat May 30, 2009 11:23 pm
They look like serious weapons :D
I was surprised you went for the 300mm.de setup to begin with TBH, done anything with the rears? Got anything planned?
e21Jason
Sun May 31, 2009 2:32 am
Nice work
I started doing this for the e21 but using wilwood disks but could not get the packaging to work due to the pad depth, wilwood seems to use bigger rotors than AP for the same pad depth but the disks are only £50 a pop.
I was working the same set up for the rear with a 3 pice disk which has an inner steel ring for the hand brake.
So if you want some matching rear calipers drop me a PM
Demlotcrew
Thu Jun 04, 2009 2:38 pm
DanThe wrote:They look like serious weapons :D
The TT setup is not bad considering that when it fist came out there was little else on the market for E30's!
Currently ive got Z1 282 X 10 on the rear with M3 calipers and a bias valve to regulate the balance.
A1BMW325iSport
Thu Jun 04, 2009 3:06 pm
Fair play thats some serious stopping power :D 8)
Demlotcrew
Thu Jun 04, 2009 3:07 pm
e21Jason wrote:Nice work
So if you wanr soem matching rear calipers drop me a PM
£50 a pop would be nice, but im hoping that because i only do about three track days a year i might be able to make the disks last a 'season'
Jason,
The rears look like exactly something ive been thinking about doing!
Ill give you a pm.
A
groselha
Sun Mar 07, 2010 6:11 pm
That's what i'm looking for. :D
Sun Mar 07, 2010 6:56 pm
Holy old thread alert Batman!
Demlotcrew
Sun Mar 07, 2010 6:58 pm
Can you believe it, ive yet to test the brakes out since fitting them! :cry:
Sun Mar 07, 2010 9:24 pm
why am i not surprised!
Sun Mar 07, 2010 9:28 pm
Only 10 months.. Well worth the spendage then.. :)
Sun Mar 07, 2010 9:29 pm
Demlotcrew wrote:Can you believe it, ive yet to test the brakes out since fitting them! :cry:
Spent so much money on parts you have none left for a track day? :D
Sun Mar 07, 2010 9:31 pm
That is my problem...
Demlotcrew
Mon Mar 08, 2010 11:43 am
Not only Money, its the time!
The car is almost done now, cage in, painted, electrics rewired, just got to fit the electric power steering, seats then MOT and TAX.
Mon Mar 08, 2010 11:59 am
Is it completely electric or electric/hydraulic? Ive looked at an electric/hydraulic before and thought about molesting it :)
Demlotcrew
Mon Mar 08, 2010 12:04 pm
Its an Electric hydraulic motor from a Merc A Class as used by the E46 GTR MS cars.
Just need to make a bracket and re route the hoses from the rack to the pump. Only Three wires to connect up for the pump! - I will fit a switch so i can turn it off for feel :D
Mon Mar 08, 2010 12:17 pm
Perfect 8)
Ive read about people trying to use these corsa? columns with an electric motor strapped to it :mad:
Have you upgraded the oil cooler? Plan to?
Demlotcrew
Mon Mar 08, 2010 12:21 pm
Hmmm, not sure on the column idea, too much faffing about to make it work! - and Corsas dont exactly have the best feedback!
Oil cooler? - The stock one is more than enough (my temps rarely go above 110degC) if i was to do one or more laps on the ring then yes i would need a Mocal (or equivalent). Thats dead easy to fit!
