CR24v Custom M52B30 FTW. New Exhaust, New gearbox and Fan.
Dezzy
- CR24v it's a lifestyle
Bob_S
at last! good job I'm here isn't it!
Looks good mate, running it in? Dan's 3ltr was run in nicely... nipped down the disused airfield by me and follwing dans advice wound it up in 4th then shut the throttle.. I got bored after the 4th run so decided I should make it more exciting and do it in 5th..
Bollocks to this 24v scrap!
Dezzy
Ha ha it will be on the stand a while mate.
Yeh your advice was key I reckon. Did not want to quad cam them coonts.
I reckon I am on course now like fingers crossed for a first key start
great progress Dezzy
bet you can't wait to hear it fire up
Dezzy
I can't mate really excited. I want to be where you are now.
Just been thinking I'm not that close really. Exhaust to finish, Z3 rack, rear discs, 5 stud conversion, rad and fan, prop etc etc.
One step at a time eh?
Dezzy
I allowed myself to do a little tarting today
I started off with a very oil ridden M50 box
Some agressive cleaner doing it's thing
After a little wash off
Oh and some engine mount brackets got a bit off the tarty goodness
They are a bit glossy but they will do.
The gearbox seamed to be leaking from the selector shaft? Is this common (easy to repace seal)
It just wouldn't do if it leaked once in!
That's all for today customers get right on my nerves
rob0r
Great project
. I'll be interested to see what figures you get out of this engine!
Most common gearbox leak, easy fix
Dezzy
Is it just a case of buy a seal bang it in Dan? How does the rod come out?DanThe wrote:Most common gearbox leak, easy fix
Re figures it puts out so will I. If a little nervous
gareth
iirc, there's a spring steel sleeve that sits round the 'knuckle'. pull this off and underneath there's a steel pin which just needs pushing through. the knuckle then comes off
not sure on how to do the rest of the job though - i never bothered on mine so i have a shitty oily transmission tunnel
oh well, that's one area that won't rust!
Dezzy
Cheers gareth I will look on Monday. I need everything to be clean. It's an illness.
- Homo Hair
This done and run in yet..?!
Dezzy
Ha ha
You must be a nightmare at Christmas.
You done anything to that M3?
- Homo Hair
Yep.. Only the fuel tank left to remove, and loom to pull through the bulkhead. Then it's out of my hands for a month or so.
Happily discovered it has a mint bulkhead after pulling the dash out
Dezzy
Cool is it going for paint?
Back to silver?
Back to silver?
S38B38
Really nice project,,
one Q,, you are using the m52 inntake manifold,, arent you
why not M50
why not M50
Sveinbjörn Hrafnsson
E30 CABRIO M70B50 V12 5lug
ALPINA B10 BITURBO 346@507
550 V12 JML Motorsport
Dezzy
M50 inlet mate.
S38B38
Ok,, i thought it was m52 ,, sorryDezzy wrote:M50 inlet mate.
Dezzy
No need for sorry mate.
Enlarged M50 throttle body too. Standard airbox though
turk
It would be awsome if u could make up something like this >>>
http://www.treehouseracing.com/index.ph ... &Itemid=35
Completely unrestricted air flo
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
Sump Baffles
TrackDays
Dezzy
Where is the filter? It looks cool. Good idea but needs to be fitered?
I don't want my very expensive engine that I have built to my own spec. It has custom parts rebore bigger pistons etc I want it to be protected.
It's a one off.
It's a one off.
- Homo Hair
Filter will be tucked down out of shot innit
(Yes M3 is going for paint/cage)
turk
I think it has a long oval filter behind the grill if i remember rightly. I saw something very similar to this In Gaydon at the Bmw show last year... looked impressive...
U could always customise a large filter yourself to offer all the protection u need
What throttle body were u planning on using?
Sump Baffles
TrackDays
Sump Baffles
TrackDays
Dezzy
Will it not be a cone effort bruv. If so I will stick with my standard air box.Jhonno wrote:Filter will be tucked down out of shot innit
Get some pics up when it's back innit.
Dezzy
M50 enlargedturk wrote:I think it has a long oval filter behind the grill if i remember rightly. I saw something very similar to this In Gaydon at the Bmw show last year... looked impressive...
U could always customise a large filter yourself to offer all the protection u need![]()
Dezzy
Just a quick one.
Gareth has all the new bearings, seals and bolts to finish my diff. I have been gay again so to go with the powdercoated case I have a special order from the mother land.
New diff cover rightness
The coated case
The coated case
Hmmm, I think the yellow bush might clash with the black case
Dezzy
Keep any negative coms to yourself thank you.
I knew you wouldn't like that pollybush. It's not the usual rock hard pastic mate.
I thought they only worked on welded diffs?
Dezzy
I have made a lifestyle choice. Gareth is fitting all new bearings, seals and bolts then welding the fook out of it.DanThe wrote:I thought they only worked on welded diffs?
I am re blacking the bonnet and re cutting the springs. Then all I will need is some tacky stickers and I will look way cooler than your grandad chariot.
keri-WMS
lol!!!! I didn't know about this - we'll need a video of the tyre noise it makes negotiating multi-story carparks!Dezzy wrote:I have made a lifestyle choice. Gareth is fitting all new bearings, seals and bolts then welding the fook out of it.DanThe wrote:I thought they only worked on welded diffs?
Dezzy
keri-WMS wrote:lol!!!! I didn't know about this - we'll need a video of the tyre noise it makes negotiating multi-story carparks!Dezzy wrote:I have made a lifestyle choice. Gareth is fitting all new bearings, seals and bolts then welding the fook out of it.DanThe wrote:I thought they only worked on welded diffs?
Don't worry my YouTube vids will be epic. Quiet rounderbouts and tesco's carparks will all be signed by me. You have herd of Mr13 well I am Mr11
- Homo Hair
McD's carparks everywhere will no longer be safe..
- E30 Zone Meets/Events Team
So now your building a "Drifter"?
I've already tagged his local drive thruJhonno wrote:McD's carparks everywhere will no longer be safe..
