E46 M3 engine into a E30.??
Nine468
Post Sun Feb 28, 2010 10:27 am
Has this conversion been done.
Putting a S54 E46 M3 engine into a E30 ?
If so could somebody be so kind as to point me in the direction of the details.
Ive done a search, but throws up SO many unrelated options it takes ages to sort through....
Ide like to maybee do this.
Thanks.
Dave W.
topbananabm
Post Sun Feb 28, 2010 10:31 am
yes it has been done into E30 m3 clive sanchez of munich motors (PBMW october issue 2009) :cool:
Cook318IS
Post Sun Feb 28, 2010 10:33 am
"glenn" on here has also done the swap. Have a search on here under his username and im sure there will be a few details on it
jaistanley
Post Mon Mar 01, 2010 8:32 am
There are a few ways to do it...
1. Run the std E46 engine loom.. This is the most difficult as it requires huge amounts of un-picking looms, hiding away E46 electronics in the E30 and fooling the ECU into working.
2. Run S50B32 engine loom, ecu and management. This has been done a couple of times with a few tweaks here and there. Good results apparently.
3. Run an aftermarket ECU on a modified engine loom. You can buy and off the shelf kit, pre-mapped. You supply an exchange loom which has a surcharge..
Otherwise, you get the engine in the same way you do an S50. New oil pump, M50 (E34) sump and oil pick up, E36 M50/S50 engine mount arms, E28 M5 engine mount rubbers, E36 M3 radiator etc etc..
hope this helps.
Jai
Steve
Post Mon Mar 01, 2010 12:43 pm
webmaster@e30zone.net
