e36 328i wagon slag
Dreamracer1
Post Tue Oct 27, 2009 7:49 pm
What a bloody relief.
This was getting like War & Peace.
See, perserverance pays.
Well done that Man!
E-mail kandkwalden@aol.com, phone 07854043093
Please buy some of the bits off this old 320i!
Post Sun Feb 07, 2010 9:59 pm
monday gone, i got my finger out and fitted this Alpina system thats been in the garage for 3 months.
The sh!tter in the air, i haven't washed it since the MOT its going well!
The pipe bore is 55mm on the alpina system 8O Same as a 540i systems! Funky X pipe at the front. The weight of it is epic, was a real struggle on my own. I bolted it up loosely together and worked back from the manifolds.
My lamba sensors are both in the manifolds, but on the alpina system it has a sensor behind the cats? Why the difference anyone know?
Horrid gay little link pipes. Three times to get this right. To get all the nuts done up, one needs to be bolted to the manifold and the other to exhaust when you offer it up
Its really quite loud! Below 3000 rpm its majorly bassy, when you rag it the note dies off at high RPM and the engine note takes over. I like it, has a real 6 pot hmm when cruising along. The car revs much cleaner top end too 8) but alpina stuff always works. Defo the modern PYF replacement car now
M50 inlet next, Kos get my bloody flywheel back please! Some lower front springs wouldn't go amiss either its a bit too high
Post Sun Feb 07, 2010 10:08 pm
Could still nail some other Alpina trinkets to it!
Kos
Post Sun Feb 07, 2010 10:10 pm
i'll get it to you on weds kermit
Post Sun Feb 07, 2010 10:14 pm
Some Alpina/US M3 cams would be nice. Get it all together in this and then transfer it into an E30!
Kos
Post Sun Feb 07, 2010 10:19 pm
si, where about is the X pipe on the alpina system , i cat see it
Kos
Post Sun Feb 07, 2010 10:20 pm
is it before the Cats?
Post Sun Feb 07, 2010 10:21 pm
yeah before the cats, it doesn't look like most X pipes but it clearly is one!
Simon
Post Sun Feb 07, 2010 10:26 pm
Nice.
These cars do sound good, even with standard systems.
I will miss mine.
Kos
its given me inspiration for my compacts centre section design
Post Sun Feb 07, 2010 10:31 pm
This sounds the tit's especially as she catches on start up. lovely mod.
town325i
Post Sun Feb 07, 2010 10:38 pm
what have you done with the old down pipes?
Post Sun Feb 07, 2010 10:42 pm
the stock 328 system I took off my breaker had the x pipe
Post Sun Feb 07, 2010 10:44 pm
oh yeah didn't notice that Lee! The old exhaust is going on the bro in laws 323, which is having a 2.8 fitted to it
Kos
Post Sun Feb 07, 2010 10:46 pm
all 2.8's have the X pipe, a some of the spaz'z who cut the cats out and resonator wonder why they loose power
Post Sun Feb 07, 2010 10:59 pm
Kos wrote:all 2.8's have the X pipe, a some of the spaz'z who cut the cats out and resonator wonder why they loose power
No cats, X pipe or resonator when M52's are fitted to E30's.
DanThe's runs an E30 325i type system im sure.
Post Sun Feb 07, 2010 11:02 pm
Love your touring. Wish I had that as a daily.
Kos
dan runs a centre box, bot sure about x pipes.
when i have centre section and de cat my compact i will be putting in an X pipe, i'll loose the resonator and put in a small centre box, otherwise it will be too loud.
Post Sun Feb 07, 2010 11:04 pm
I think a stock 2.5 system is too small bore for a 2.8
Post Sun Feb 07, 2010 11:15 pm
Simon13 wrote:I think a stock 2.5 system is too small bore for a 2.8
Im sure thats the system people use on these conversions.
M30 uses the M3 system.
Post Sun Feb 07, 2010 11:19 pm
Doesn't mean its right or the best exhaust for the job though. Stock M52 2.8 pipes are 50mm, which is E30 M3 size/E30 Alpina. e30 325i systems are 44mm. The exhaust i've just put on which is a proven performance system is nearly 10mm bigger! So i'd be trying to get at least an M3 system on my M52 if i was doing a conversion. Just my logic but wtf do i know!
Post Sun Feb 07, 2010 11:24 pm
Im onlu going by what other people have said that have done these conversions.
Yep, mine uses a standard 325i Scorpion system, no X pipe, when I can I will do a before and after dyno run with a 325i system and an M3 system, might even bodge an X piece in :D
What alpina is it off Si?
Post Sun Feb 07, 2010 11:36 pm
I checked the part numbers when i got it and the same system is fitted to the 2.8/3.0 and 3.2 cars
Bob_S
Post Sat Feb 13, 2010 2:41 pm
I used a fritz system on my 24v motors was loud too until I knocked 7 shades out the centre box and split it!
Bollocks to this 24v scrap!
Post Sun Feb 21, 2010 3:55 pm
More bodging this weekend! M50 inlet on
Fuel rail bodgery!
Everything thats molested isn't seen. I've got a badly split throttle body pipe which needs replacing ASAP. So from that i can't say i've noticed any improvement bar a loss of low end grunt. But the e36coupers all say it needs a few weeks to let the ECU settle.
Lets hope so, the M20 fly and clutch will regain low end pick up i'm sure though
winx
Post Sun Feb 21, 2010 6:40 pm
Good work fella, nearly came round for a cuppa today!
Post Sun Feb 21, 2010 10:34 pm
you should of bert!
Simon
Post Wed Mar 10, 2010 9:55 am
Simon, what's it ride like on those billies?
I'm keeping my E36, and ditching the E30 8O
Looking to refresh the suspension.
Post Wed Mar 10, 2010 10:03 am
I had a split inlet on mine.. When I taped.. I mean replaced it, fook me did it make a difference!
Post Wed Mar 10, 2010 10:35 pm
Si, the billys ride quite hard tbh. I think for a daily the boges ride that bit softer
eko
Old timer
Post Wed Mar 10, 2010 11:12 pm
Simon13 wrote:More bodging this weekend! M50 inlet on
Fuel rail bodgery!
Any DIY tips on thos mod Si?
Got 2 to do myself very soon,at least one of those(my own) can and probably will be pikey spec :P
Post Sat Mar 13, 2010 9:19 am
Dans the one to ask, i'm surprised you haven't done it a few times Tony?!
I'm doing another today there seems to be alot of ways of doing it using various M50/M52 parts all mixed up. As long as nothing fails off and theres no air leaks game on!
nickso
Post Sat Mar 13, 2010 10:00 am
this is a good link if you want to use m50 bits.
http://www.rmeuropean.com/bmw-m50-manifold.aspx
'88 e30 328i M52 track bint.
Ant
Retired Team Member
Retired Team Member
Post Sun Mar 14, 2010 12:14 pm
Dont remove the zyclon valve doing this mod !!
you will have a lot of oil in the intake, the oil and oil fumes need to be split so the oil has a trap and falls to the sump via the dipstick tube, the fumes only to the intake manifold.
the intake temp sensor must not be overlooked either, M50 unit is not the same as M52.
