started rehousing pride and joy m52 into new p&g e30
slidey73
None vanos 2.5,24v,out/in,MY,e36,2.8i ,,,All went well today got both engine`s out with help from Mr,B a mate
, Was not to bad had to jack up rear to make pulling them out sweet
tip from jimmymig , Sump swap oil pickup all there so quick clean pop them back on , Putting 2.8 in tommorow then all the fun really starts . i,v looked and been told about but i hate wires
Well hope i`v took something in ,vanos where and
ews will not start with out it AAAA I see all wires so let`s get
with it am sunday , I do get a bit
when i get stuck
will post my fun and games tommorow night
Nice one
If you want a plug n play engine loom sorting then speak with DanThe
Kos
slidey73
I`ll try first, told not to bad if get
then i`ll try a plug and play
slidey73
buy a com na ta e30 nowKos wrote:
Kos
in english please with less of the smiliesslidey73 wrote:buy a com na ta e30 nowKos wrote:
slidey73
dyslexia reading and writing = bad english and smilies coz i`m happy so cheer up or just no read( miz gut ) have aKos wrote:in english please with less of the smiliesslidey73 wrote:buy a com na ta e30 nowKos wrote:
MarkT
Coo, get some pics up mate. Where in swsindon are you? I'm from wantage
E30 340i project in progress now 328 turbo
Breaking '97 728i Auto box, tubular manifolds and other morsels.
For sale E34 M50 sump, pick up and dip stick. PM for de
slidey73
pic`s will be soon i hope groundwell end near A419 .MarkT wrote:Coo, get some pics up mate. Where in swsindon are you? I'm from wantage
slidey73
Hello to all
I have 2.8l m52 engine swinging on a chain just above its new home e30 320 1988.
I need main engine harness connector diagram for the above cars so i can make a loom adaptor.
thanks
thanks
slidey73
Ok Thankswillnz wrote:Also, please do not go posting multiple topics around the forum, keep it in one place. It only causes confusion. I have removed the other topic in tech help.
The colours are diferent on the e30 conector. Should I just match up the pin numbers and ignore the colours.
slidey73
Nice one, We could match 1 or 2 but that was all , Thanks will try and get it in tommorow ,
willnz's chart shows the E30 colours on the car side of the engine plug and socket, not those on the old engine loom.
Dave_M3
Best not to get hung up on the colours anyway and focus on getting the pins right as lots of people have different coloured wires and if you go by one of them it could mean you'll be short a working ECU
slidey73
Thanks guy`s with this i`m sure to have her in and running soon if not tomorow big,,TA
Not so hard
Not so hard
slidey73
Hi
EWS FUN NOW
Transmitter module Pin 1 to Immobilizer module
Pin 2 to Switched Live
pin 3 to Earth
Electronic Immobilizer Module Pin 1 to 15 ?
Pin 4 to ECU on blk/vio
Pin 5 to Perm live
Pin 12 to ECU on black wire
Pin 13 to transmitter module
Just need to confirm the wiring for the above modules whats needed is the above correct ?
EWS FUN NOW
pin 3 to Earth
Pin 5 to Perm live
slidey73
slidey73
I NO THIS
slidey73
Hi
M52 2.8l has been dropped into an E30.
engine turns over - fuel pump primes but wont start. Fault codes show EWS and air intake temp.
injectors have voltage but no pulse.
Pics are coming soon.
slidey73
Hello again iam using the key with chip still inside taped too the antena.No click heared .Fault codes for ews,air temp sensor and no pulse too injectors.thanks for all the help
slidey73
Hi
Same question as above EWS makes no clicking noise. how do i fault find this problem.
EWS has been fitted as per diagram on this site. i've checked all cables for contineuity.
Should it work alone or does it need data from ecu.
thanks in advance
thanks in advance
slidey73
HELP STUCK ON DRIVE .Slowly giving up .. Now looking for another car .e30 dead . All done as told and no pulce to injetors . ews has got no click . Any one close to me that has done this before . or no someone that can help.............. e30 drive way in swindon...................
slidey73
..? siemens 5WK9 032 D13 .. ECU in 328I N.Reg not the bosh ecu, are all the wires the same? . All so look`s like it came from a 528i found this... http://www.megatec.gr/BMWfull.htm ... if you can help would be grate..
slidey73
GOT PIC`S FROM WHERE I GOT IT http://www.pistonheads.com/sales/largep ... W&model=^3[:digit:]*
http://www.pistonheads.com/sales/largep ... W&model=^3[:digit:]* http://www.pistonheads.com/sales/largep ... W&model=^3[:digit:]* WILL PUT NEWER PIC`S SOON
gsxr750 spin`s up well & e30.328i new toy
Bob_S
ecu, ews box and key need to be from same car.
key might need wiggle to connect successfully to ring
if all done and not working, recheck ews wiring
Bollocks to this 24v scrap!
slidey73
I`m so happy i could
Will post pic`s of change when i can shrink there SIZE as only got dongo
NOW FOR THE BODY
hope to see some of you this year at a meeting or two
