Always an interesting topic this one !! Ive had many cars and bikes over the years, and this scenario often crops up. The bottom line is as Kos and others have pointed out is that if you transfer the ID to another shell then its a ringer !!
Im sure many other car make owners are doing similar rebuilds and restores using the same method. .
The daft thing is that if you buy a "heritage" shell for an MG or old mini etc then its totally legal to transfer the ID, same with Land Rovers if its a brand new chassis. But not the case if using
a good solid second hand chassis.
The question also arises , even its a new shell or chassis , then does the original status or model still remain?? I think this was raised a while back in the rather heated topic about
Felixs Alpina which had been reshelled , therefore was it actually still an Alpina or not !!
As for changing engines, thats got daft aswell . Got a friend whos got a 90cc Vespa and has
put a 50cc engine in for his lad, and DVLA want proof or dealer letter /engineer report etc that it has been reduced in engine size before re sending V5 back to them ..
Brians logic works for me. Fix or repair one bit, then another , and another, and some more etc etc, just like Triggers Broom !!!
Re Shell Advice
- Kos
- Contact:
well, i have an idea. i'll start buying up clean shells cut off the ID's, acid dip them , primer them store them and in 10 years time sell them
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
- Brianmoooore
But not if you transfer another shell to the ID; especially if you do it bit by bit!scootlife wrote:The bottom line is as Kos and others have pointed out is that if you transfer the ID to another shell then its a ringer !!
- Brianmoooore
You find your own idea!Kos wrote:well, i have an idea. i'll start buying up clean shells cut off the ID's, acid dip them , primer them store them and in 10 years time sell them
- Kos
- Contact:
Brianmoooore wrote:But not if you transfer another shell to the ID; especially if you do it bit by bit!scootlife wrote:The bottom line is as Kos and others have pointed out is that if you transfer the ID to another shell then its a ringer !!
thats like saying " it was the bullit that killed him, and not me even though i pulled the trigger" in the eyes of the law its not legal.
ultimately, it depends how bad the shell is. no one actually knows at this time.
i'm sure that if some one stockpiled shells and sold them legitimately they can be sold with out ID's and that would make the whole re shell saga easier to stomach with potential sellers/buyers
i can see any future buyer being put off buy a re shelled car, i know i would be.
is the OP going to have the cars in the same original colour, correct spec and fit things back in like the black headlining? if the jobs done right then thats fine, but it mat still be easier to repair the rusty areas, but we dont know yet
IG Pukar.Designs
IG Pukar.Designs
- Kos
- Contact:
Brianmoooore wrote:You find your own idea!Kos wrote:well, i have an idea. i'll start buying up clean shells cut off the ID's, acid dip them , primer them store them and in 10 years time sell them
IG Pukar.Designs
IG Pukar.Designs
scott180gtb
You can all she the rusty beast in the photo gallary under 328i M20 sport resto. Lots of advice and lots to think about! Has anyone got a clean schwarts phase II.
Cars
2007 VW Caravelle 2.5 TDI 250 bhp 550 NM
1989 325i Sport Gone
2003 E46 320d Touring
1998 E36 M3 EVO Track Toy
1996 E36 328i Sport welder-up project
scootlife
You might be on to something there !! Worded that way is not wrong at all, Ever thought of being a barrister !!Brianmoooore wrote:But not if you transfer another shell to the ID; especially if you do it bit by bit!scootlife wrote:The bottom line is as Kos and others have pointed out is that if you transfer the ID to another shell then its a ringer !!
- Kos
- Contact:
thats nothing to worry about what so ever.scott180gtb wrote:You can all she the rusty beast in the photo gallary under 328i M20 sport resto. Lots of advice and lots to think about! Has anyone got a clean schwarts phase II.
IG Pukar.Designs
IG Pukar.Designs
I've seen much, much worse restored. No need for a re-shell.scott180gtb wrote:You can all she the rusty beast in the photo gallary under 328i M20 sport resto. Lots of advice and lots to think about! Has anyone got a clean schwarts phase II.
Check this resto out
http://www.detailingworld.co.uk/forum/s ... light=325i
