high comp low comp differences
baptie0
how can I identify the lower compression type m20b25 engine?
badassyas
Ant
- Retired Team Member
without stripping is easy.
look @ the engine code. 25 6 k1 is KAT prep 8.8:1 Cr , 25 6E1 is 9.75:1 higher CR.
codes are intake side near the sump gasket face , easily seen with a torch and some wire brush action.
Email FTW
baptie0
Thanks for the help
