switchable auto 325 kickdown not working
- popupstands
I have a switchable auto 325 and the kickdown has never worked since I purchased car, I don't think their is a cable!! as its switchable is this true?I feel its probally electrical problem somewhere
- popupstands
any guys know about autos, and kickdown problems (well no kickdown)
Guest
I know the mechanical auto has a cable operated kickdown but I'm not sure about the switchable box - maybe it has an electronic one. Search for a wire or cable coming from the button that the accelerator touches when it's fully depressed. Remove the lower portion of dashboard just below the steering wheel and have a good look.
mrLEE30
There is a switch under the accelerator pedal, this is your kickdown switch, you do have to push quite hard to activate it (so assuming that is not the problem!) it is i an electrical contact so check it is not stuck or badly adjusted. (i.e. when on full throttle it should be depressed fully) if not then check the wiring etc. will look at mine to see where it goes.
mr lee
mr lee
- popupstands
I have replaced switch I think it must be electical
- popupstands
does anyone have wiring details for switchable auto box?
