Beemerlad's M52 Chromie
Dezzy
- CR24v it's a lifestyle
Hasn't stopped here either mate. Poo isn't it. I hope to get that motor running this week might have to ring the 24v helpline to make sure of no more school boy errors.
The car is now home and sharing driveway/front garden space with the rest of the fleet. Was a bit of a surreal trip back home at 60mph 6ft from the rear of my mate's 328i.
The M10 lump on this thing sounds sweet as, don't worry, I'm not becoming sentimental.
Thanks again to Dezzy for all the help with this chariot
Dezzy
Not a problem mate. The straight bar is a bit strange to start with isn't it mate. Bit close isn't it. Glad it's sorted finally.
Not much to update, but today I made an effort to get my overalls on and brave the -2 temp and the occasional snow shower.
Got the front bumper & panel off and lights etc. Then got underneath and undid the front section of exhaust. The prop centre bearing and carrier is well mullerred and the transmission tunnel is rather compacted, so much that there are some marks on the prop front section where it has rubbed on the prop.
All I have left to do now is unbolt the prop and I can lug the engine & box out. Started late and had to knock off at 3.30 to go and pick Michelle up from town.
Nowt going on until next weekend now. Have just ordered a car creeper to keep my arse off the wet floor
Dezzy
Good man. You have done better than me. We had 3" of snow last night so again I did nothing.
drop the whole subframe,g-box, prop and front suspension out the bottom.
it.s less hassel.
bloody cold though
it.s less hassel.
bloody cold though
+ a yard full of scrap turds
Is there something your not telling us......... Reliant Robins
leeparkes
I agree with Magpie on getting it all out in one go,much easiermagpie wrote:drop the whole subframe,g-box, prop and front suspension out the bottom.
it.s less hassel.
bloody cold though
Drops like a donkey giving birth
you know it makes sense
"Drops like a donkey giving birth"
Sod all work done to the car, but I have treated myself to a creeper to help the winter driveway mechanic
Naturally I have already been for a tour of the house on it
Dezzy
I know them wheel look a touch bigger than they are mate but I reckon paint them silver and tyre them up for now. They look cool in your sig.
yeah I may well do mate, it won't look as cool as the sig, but it's one thing less to fanny about with I guess
well the weather is forecast to be a balmy 5 degrees tomorrow and sunshine. So the plan is I'm off for a quick scrapyard dig tomorrow morning and then back home and pull the engine & box out, plus whatever else I have the enthusiasm to remove.
Dezzy
Rape her lee.
Remember that loom for your good buddy.
what do you need again mate, was it for the clock or something?
Dezzy
clock loom mate yeh. CheersE30BeemerLad wrote:what do you need again mate, was it for the clock or something?
Ollie_bwoii
Nice to see you using the ronal's.
they look the shizzle don't they. Must get saving
Dezzy
Or just get some of the stock you have in the garage on eBay mate.
Ollie_bwoii
They really do.
What will a set of those cost?
Have you seen this before? Its simply stunning.
If you haven't and want more pics, give me a shout.
good point mate. I'll dig all the shite out tomorrow and get some pics for an ebay fest. Got a set of 14" bbs lookylikeys which I foolishly bought thinking they were the pukka 15" bbs for Michelle's golf, only to be gutted when I realised they were 14's
Got a set of 18" BK's off the soarer, only 7.5" wide so ideal for scooby twats & MR2 deviants
16" mim 5 spokes 4x100 (but one bent)
14" x spokes.
That lot must be worth £150
14" x spokes.
Ollie, post more pics of that Chromie on ronals
They are not actually that expensive, only in 15's. a set of 4 brand new is £450
Ollie_bwoii
Thats cheap considering how nice they are.
Oh and here you go:
Oh and here you go:
Good man, they look HAWT
Dezzy
That does look amazing.
Probs a bit more with the right buyers lee. Wack them on mate see what happens.
Top pics ollie.
Top pics ollie.
I'd forgotten this bitch likes to fight
Got a little bit done after getting back from the frag yard. Prop undone at the gearbox end, slave cylinder off, removed ECU and had a moment of "you stupid cooooont" for not removing it sooner fearing it may have got wet, but thankfully all good.
Was a proper mission trying to get access as the driver door is crumpled right up against the steering wheel and I had to destroy a good under dash panel to get it off
I then had another fight trying to get the ECU plug and part of the EWS witchcraft back through the poxy hole in the bulkhead. Got stuck upside down with my head in the driver footwell a few times
Inlet manifold off and everything unplugged but then simply ran out of daylight again and thought I had better give up rather than get stuck half way in the dark.
I'm really annoyed it's gonna be next weekend before I get to work on it again, at least the daylight hours are going in the right direction now. The car creeper was a god send as there was 1/2 an inch of water underneath the car near the gearbox.
billgatese30
Car creepers are worth their weight in gold Lee (as you have found out today). Mine is like yours but has the adjustable head rest too.
The only thing I noticed is they do reduce the amount of room you have under the car. Even with the axle stands fully extended, it was tight when wielding the spanner on the propshaft bolts. There wouldn't be room for an executive headrest too
billgatese30
exec headrest is only good with extra high stands or when your in wheel wells etc but it does come in handy at times. but any creeper does make your nips scratch the sump plug if the stands aren't at full height though
Dezzy
Are they any good for gravel drives?
Fooking thought not.
Sounds like your moving in the right direction now mate. I must try harder now.
Just concrete it Dez, fit a huuuge carport type canopy thing to the side of the house, gravel board between next door and a nice big pair of gates at the front. Perfect
Dezzy
DanThe wrote:Just concrete it Dez, fit a huuuge carport type canopy thing to the side of the house, gravel board between next door and a nice big pair of gates at the front. Perfect
Yeh you can imagine the grief I get for having the moredoor on axle stands outside the kicken window. Never mind blocking all the light.
Cheep fags at the top end would be nice mate but I have to get the moredoor finished first.
Now the snows gone I am going to be in there like swim wear.
Daf318is
Dear me - all this talk of car crawlers and stuff! Be men for goodness sake, just lie in the puddles and cold and get on with the job! Bunch of girls
Now driving an E46 320D touring
Says Dafs, sitting in front of the heater in his dads purpose built garage with pit
Daf318is
You mean the garage where a pipe burst last week and filled with pit to the brim with water and 2 inches of water on the garage floor?DanThe wrote:Says Dafs, sitting in front of the heater in his dads purpose built garage with pit
