2.3 24V into bmw e30 what do you think??
macko1000
Post Thu Jan 14, 2010 7:31 pm
If someone have seen swap like this before or do this in the past please write something in this topic. Especially in details, everything what you know;) thank you very much!
PS: sorry for my english Im not from england.
martinpallot
Post Thu Jan 14, 2010 7:34 pm
No such thing as 2.3 24v engine from BMW
Andy325i
Welcome :)
I guess you mean the M52 B23? (or is it B25?) Anyway its a 2.5, so not a bad option, but unless you have the engine already get an M52B28 in there and tune it ;)
Lots of 24 valve cars here :)
Andy
macko1000
Post Thu Jan 14, 2010 7:37 pm
sorry its 2.5 170 hp engine. but it is called 2.3
macko1000
Post Thu Jan 14, 2010 7:43 pm
yes its m50 b23 engine:) well i dont want to have something so fast like 2.8;) 170 hp will be enought for me:) I need some technical informations. Is there any problems to put this engine into my car? I have never seen e30 with this engine and I dont know for sure that its possible.
baptie0
Post Thu Jan 14, 2010 8:33 pm
Post Thu Jan 14, 2010 8:45 pm
Fitting the M52B23 is exactly the same as fitting as fitting the M52B28, and largely the same as fitting the M50B25. All the info you need is in the epic thread mentioned above, and, as you will see, there is no one correct way of doing it.
P.S: If your car is left hand drive, a considerable amount of the info on here will not be relevant.
Post Thu Jan 14, 2010 9:57 pm
Plus, it will also respond a lot better to any mods you do than an M50 would
Post Fri Jan 15, 2010 12:21 am
M52B23 is incorrect!
Its M52B25.
Coyote_ar
Post Fri Jan 15, 2010 9:57 pm
the car is called 323ti or 523, but the engine is M52B25 as bss325i said.
cheers.
leeparkes
Post Fri Jan 15, 2010 10:50 pm
Do these M52/b25's have an alloy block like the b28?
Post Fri Jan 15, 2010 11:14 pm
Coyote_ar wrote:the car is called 323ti or 523, but the engine is M52B25 as bss325i said.
As my brain knows, but didn't quite communicate to my fingers!
Post Thu Jan 21, 2010 9:30 am
leeparkes wrote:Do these M52/b25's have an alloy block like the b28?
Yes
Post Thu Jan 21, 2010 9:47 am
Same block in fact
