Scuttel pannel
Sash_332
Post Sun Dec 20, 2009 7:53 pm
Seen that e30's suffer with these,i was servicing mine last week....leant on the scuttel pannel closest to the bottom of the windscreen on the pass side and my palm put a whole through it... the other side has alot of fiber glass over where i think the previous owner did the same... it looks shoddy as hell.. whats best to cover the hole??? and of course respray after.
Thanks in advance
Post Sun Dec 20, 2009 10:05 pm
Weld a patch of metal in place. You might have to take out the windscreen as well.
Post Mon Dec 21, 2009 12:18 pm
Weld a new scuttle panel in, still available from the dealer IIRC
darkchild
Post Mon Dec 21, 2009 9:17 pm
ImysE30 wrote:Weld a new scuttle panel in, still available from the dealer IIRC
They're about £50 iirc when I enquired recently.
Mine was rotten at one end and I had it repaired by a bodyshop - screen out, new metal welded in and plenty of wax behind. Not cheap but hopefully should be good for another decade!
kieran325
Post Mon Dec 21, 2009 10:32 pm
This was the size of a 5 pence piece...
Nath325i
Post Mon Dec 21, 2009 10:37 pm
i got a new scuttle panel for the tech 1 last month and it was £38
minicooper172
Post Mon Dec 21, 2009 11:04 pm
It's a pain in the arse. Brazed panels, what idiots.
Kos
Post Sat Dec 26, 2009 7:18 pm
minicooper172 wrote:It's a pain in the arse. Brazed panels, what idiots.
Post Sat Dec 26, 2009 7:27 pm
+1. :?
Cook318IS
Post Sat Dec 26, 2009 7:35 pm
Where abouts are the scuttle panels on realoem/ bmwfans.info? i can't seem to find them :?
skipunda
Post Sat Dec 26, 2009 7:44 pm
why does the scuttle go on the drivers-side?
Chris
Kos
Post Sat Dec 26, 2009 7:46 pm
its boths sides that go
i usualy see them go on the passenger side, but seen drivers side too
minicooper172
Post Thu Dec 31, 2009 6:40 pm
bss325i wrote:
+1. :?
They braze the joint, meaning that you need brazing kit to fit new metal, or remove the brazed joints. You can't weld to braze.
