Seen that e30's suffer with these,i was servicing mine last week....leant on the scuttel pannel closest to the bottom of the windscreen on the pass side and my palm put a whole through it... the other side has alot of fiber glass over where i think the previous owner did the same... it looks shoddy as hell.. whats best to cover the hole??? and of course respray after.
Thanks in advance
Scuttel pannel
They're about £50 iirc when I enquired recently.ImysE30 wrote:Weld a new scuttle panel in, still available from the dealer IIRC
Mine was rotten at one end and I had it repaired by a bodyshop - screen out, new metal welded in and plenty of wax behind. Not cheap but hopefully should be good for another decade!
minicooper172
It's a pain in the arse. Brazed panels, what idiots.
- Kos
- Contact:
minicooper172 wrote:It's a pain in the arse. Brazed panels, what idiots.
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
+1.Kos wrote:minicooper172 wrote:It's a pain in the arse. Brazed panels, what idiots.
Where abouts are the scuttle panels on realoem/ bmwfans.info? i can't seem to find them
- Kos
- Contact:
its boths sides that go
i usualy see them go on the passenger side, but seen drivers side too
IG Pukar.Designs
IG Pukar.Designs
minicooper172
They braze the joint, meaning that you need brazing kit to fit new metal, or remove the brazed joints. You can't weld to braze.bss325i wrote:+1.Kos wrote:minicooper172 wrote:It's a pain in the arse. Brazed panels, what idiots.
