aha
, ill get them later then, too dark to go fafin about now
ant the ecu number is where then, on a lable on the underside i can see? or the side the is against the roof of the glovebox?
also
there was a screw in the big plug ( small hole on the right hand side of the plug) i removed it, should i do that or is it not part of the process?
