Thats typical as my donor has air conleeparkes wrote:Aircon rad is no good because its too deep
I think i posted pics in the M30 sticky
Yep, fits perfect and works well!shedrool83 wrote:Yeah noticed you used the m20 rad for a bit.leeparkes wrote:M20b25 rad works fine and never overheated even stuck in traffic on hot days but the fan will be on a lot more than if your using e34/28 ect...
Did you use the electric air con fan from the e34?
bugger, i didnt know about this!!leeparkes wrote:Quick update,
ive done the wiring mod on the loom,
instead of messing with the c101 plug(ie pulling pins out)i cut into the loom
i unravelled some of the tape what covers the loom then picked out the 2 wires (white with black stripe & black with purple stripe),sniped and swaped them over then wrapped it back up with insulation tape.
X2, tried for a good hour to get them out. Gave up out of fear of breaking connector.Rav335uk wrote:I had difficulty in pulling the pins out, so safer for me rather than demaging the connector.
Now he tell's us, lolgareth wrote:there is a keeper plate on the back of the connector, just unlock the clips and twist it a bit
The E34 linkage would need to be shortened when fitted to an E30, or the gearlever comes out too far back.icleanmotors wrote: second is gear linkage i saw that you bought some kind of short shifter? is this something i need, the fella i bought it from said i would need to get the oringal one cut an shortened.
I'm using those too, and paid about that also.gareth wrote:my mounts are the ones lee mentioned above, from www.e30.de
tino on there is a top lad and iirc, they're about £130 posted or thereabouts, depending on what the euro/pound exchange rate has done since i bought mine
The 325i system works but its the E30 M3 system you need with twin 50mm bores.icleanmotors wrote:just need a find a 325i s/s exhaust system.
Is this the scorpion off pacerpete? if so i was going to buy that but he wouldn't post it (needed splitting in two) DTM pipes i think.icleanmotors wrote:ive just picked up my m3 exhaust so all is lookin welll...
It will be more like 70mm springs once the M30's in there, mine gained 69kg over an M20 and it droped about 15mm at the fronticleanmotors wrote:now the new task is 60mm lowering springs,
