Err, that's the oil cooler thermostat. . . oil pressure releif valve is only accessible with the sump off.billgatese30 wrote:This is the best diagram I have unfortunatley. It is held in place under spring pressure and retained by part 7. It limits the amount of pressure just prior to the filter and vents any excess to the sump.
I would imagine that the m21 pickup is used so that it reaches deeper into the deeper oil pan on the modified sump, which in itself helps negate the problem of the oil climbing the sidewall of the standard sump and starving the pickup of a suitable supply.
325 Engine/Engine Builder
e301988325i
I said:
e30topless said:
lock the wife in there
billgatese30
I've always read that it was the pressure relief valve, oh well, learn somthing new everyday
e21Jason
Nigel who id is alloyproducts on the zone does big bafle sumps
jason
jason
e301988325i
parts 14 through 17 relate to the pressure relief valve assembly, the spring is (15) a different part number than the m21's
E30 324td
No. Description Supplement Qty From Up To Part Number Price Notes
01 Oil pump 1 11411275093 $221.11
02 GEAR WHEEL 1 11411271135 $50.63
03 GEAR WHEEL 1 11411271132 $50.63
04 OIL PUMP COVER 1 11411275095 $53.57
05 OIL STRAINER 1 11411706896 $3.08
06 Protective cover 1 11411720897 $8.23
07 Hex Bolt with washer M6X30-Z3 4 07119913500 $0.60
08 Valve 1 11411275097 $3.35
09 Compression spring 1 11411287250 $1.67
10 Flat Washer 1 11411275099 $0.42
11 Lock Ring 28X1,2 DIN472 1 33307745110 $0.51
12 Hex Bolt M8X25 3 07119913653 $0.47
13 WAVE WASHER B8 3 07119932095 $0.09
14 Connection piece 1 11411267796 $14.91
15 Stopper 2 11411280950 $0.15
16 GEAR WHEEL 1 11411713428 $50.63
17 BEARING COVER 1 11411275867 $47.43
18 Gasket ring 1 12111363190 $1.59
19 NEEDLE SLEEVE 11,4X16 1 11111265412 $5.90
E30 325i
01 Oil pump 1 11411720898 $221.11
02 OIL PUMP HOUSING 1 11411273081 $56.95
03 OIL PUMP COVER 1 11411273084 $49.87
04 OIL STRAINER 1 11411706896 $3.08
05 Protective cover 1 11411275100 $1.33
only applies to
-- Oil pump ? 11411273080 ENDED
05 Protective cover 1 11411720897 $8.23
only applies to
-- Oil pump ? 11411720898 $221.11
06 WAVE WASHER B6 4 07119932099 $0.38
06 WAVE WASHER B6-ZNS3 4 07119904496 ENDED
07 Hex Bolt M6X35 1 07119901189 $0.60
07 Hex Bolt M6X30 4 07119913575 $0.20
08 GEAR WHEEL 1 11411265095 $50.63
09 GEAR WHEEL 1 11411280880 $50.63
10 Connection piece 1 11411267796 $14.91
11 Stopper 2 11411280950 $0.15
12 WAVE WASHER B8 3 07119932095 $0.09
13 Hex Bolt M8X25 3 07119913653 $0.47
14 Valve 1 11411265097 $7.06
15 Compression spring 1 11411710795 $1.52
16 Flat Washer 1 11411265098 $0.20
17 Lock Ring 26X1,2 1 07119934635 ENDED
18 GEAR WHEEL "B" 1 11411713218 $50.63
only in conjunction with
-- Intermediate shaft B 1 11351716095 $145.96
I said:
billgatese30
Well there you go, so I assume you could just change the spring then rather than finding a complete m21 pump? or are they different externally as well?
e301988325i
I've checked through the part numbers, very little matches, notably the important oil pump gear wheels.
But I would bet that the stock pump with the m21 spring would be a sound upgrade if the sumps off. I wouldn't try the spring alone without a permanent oil pressure gauge to keep an eye on things, and I would also put 0w(cold winter viscosity)/40(hot oil viscosity) to give the pump an easier life with cold thick oil.
on a seperate note - The spring is used with the thermostat to maintain oil pressure when diverting to the oil cooler IIRC
I said:
billgatese30
That may be where everyone gets confused then.
At least we have kept his thread at the top and I have learnt something new.
ShakeyC
Oil pumps have nothing to do with oil starvation directly, starvation occures when there oil pump pickup has no oil to suck on or too much oil pressure and turns the oil into a frothy coffee.
Adding 'wings' alone to a sump just provides a nice large area for the oil swish into away from the oil pickup causing same problem again sucking on nothing. The way to get around it is to fit an oil scraper to girdle bottom of the block and carefully create baffles in the sump pan in such a way oil to keep most of it around the pickup from all directions. With wings, baffles and scraper you can safely increase oil capacity and use the correct oil grade for the E30 as always.
Also note the sump is very porous ali welding it needs to be thoroughly cleaned at a machine shop otherwise the welds will fail! Or use the dishwasher if you like to winding up like your misses
N00b
All a crank scraper does though, is eliminate windage. While eliminating this is a good thing, the engines ability to draw oil isn't affected either way.ShakeyC wrote:Oil pumps have nothing to do with oil starvation directly, starvation occures when there oil pump pickup has no oil to suck on or too much oil pressure and turns the oil into a frothy coffee.
