Got my self an off red (slighty pink!) 316i tourer.
I have tried T-cut and polish with some success.
Does anyone have advice on how to get it back to the original shiny red with out resorting to a respray.
Any advice welcomed.
Ta
Le Mans Classic 2006
Where are you based? may get a memeber who can MOP it for you (i am based on Nottinghamshire / derbyshire border and may be able to help if you are local)Fletch23 wrote:Does the G10 have to applied with a mop or can it be done by hand?
.....and then repeat every 2-3 weeks? It's faded back to pink alreadyAlex wrote:Clay bar, Polish and plenty of wax should do the trickgrantfk10 wrote:Ok, can someone run through the best way to deal with this one:
Thanx in advance
yep every couple of weeks, only thing you can do unless you want to respray itgrantfk10 wrote:.....and then repeat every 2-3 weeks? It's faded back to pink alreadyAlex wrote:Clay bar, Polish and plenty of wax should do the trickgrantfk10 wrote:Ok, can someone run through the best way to deal with this one:
Thanx in advance
Not quite true, if you polish then seal it with a good wax or sealent the fading wont happen so soon.Alex wrote:yep every couple of weeks, only thing you can do unless you want to respray itgrantfk10 wrote:.....and then repeat every 2-3 weeks? It's faded back to pink alreadyAlex wrote: Clay bar, Polish and plenty of wax should do the trick
