big brake kit.....???
k13
Sat Oct 31, 2009 6:40 pm
guys...im after a big brake kit for my 325i se 4 door manual facelift F reg 1988.
ive been searching around and ive found these 4 pot caliper brake kit called hispec for £500.00 per set.
http://www.ruderacing.co.uk/Brakes-Brak ... _info.html
what do you guys think of it , good or bad ?
what other sites sell e30 big brake kits ?
thanks.
k13
Sat Oct 31, 2009 9:29 pm
do http://www.uucmotorwerks.com/ deliver in uk ???
fuzzy
He who sleeps with "Gingers"
Sat Oct 31, 2009 9:31 pm
keri-wms on here does kits at good prices. ive heard mixed reviews about hi spec , their main issue seems to be their after sale service ,or lack of ,if somethings gone wrong. ive also heard of problems caused by no dust seals on some of their stuff.
Dave_M3
Sat Oct 31, 2009 9:56 pm
I'd go with Keri too as you can get the whole kit for 800 quid and he's great to deal with.
Plus, the option of fitting under BBS 15"s is a huge bonus!
320dave
Sat Oct 31, 2009 10:14 pm
i know there is some engineering involved but are these any good as a cheap option??
http://cgi.ebay.co.uk/Fiat-Coupe-Turbo- ... 23038c8735
e301988325i
Sun Nov 01, 2009 4:27 pm
depends if you're confident enough to make and design highly stressed parts of your braking system?? They'll work and have been done before. best check pad compound availability too.
www.rallydesign.co.uk
Sell the wilwood E30 kits, have heard bad stories about their braided brake lines so best get different ones, plus you'll also want 2mm wheel spacers from 'keri-wms' on here if you're running 15" BBS wheels.
One thing to consider is keri-wms's kit and rally design's kit use vw corrado g60 discs, with the centre bored +1mm and the retaining screw hole relocated. This means cheap, readily available replacement discs, ie GSF hold brembo discs in stock in most branches.
Ask hi-spec what they want for a set of e30 kit discs, just something to consider
I said:
e30topless said:
lock the wife in there
k13
Sun Nov 01, 2009 4:52 pm
ive been told that the wms brake kits come just for the front wheels but not for the rears?? why is that ??
e301988325i
Sun Nov 01, 2009 5:09 pm
That's the same for all the kits. . . The front brakes do most of the work.
It's a simple job to upgrade the rear calipers to E30 M3 spec calipers (E34 5 series or E32 7 series are the same IIRC) after or at the same time as upgrading the fronts. There's also a rear disc upgrade to Z1 280mm discs, but it's not worth it (I know I've done it at ridiculous expense).
I said:
jenad
Sun Nov 01, 2009 5:41 pm
You can use the larger Touring caliper with 35mm bore to increase brake performance a little at the rear axle.
Dave_M3
Sun Nov 01, 2009 6:00 pm
What size are the pistons on the normal calipers at the rear?
BadDave
Sun Nov 01, 2009 7:11 pm
k13 wrote:guys...im after a big brake kit for my 325i se 4 door manual facelift F reg 1988.
I'll be removing my 302mm x 28mm setup and Brembo 4 pots in the next week or so,as I'm upgrading to 6 pots and 335mm disks.
The 302's will require skimming though or I can supply details of the disks I use with this particular setup,so you can obtain new ones
rix313
Sun Nov 08, 2009 5:29 pm
Dave_M3 wrote:What size are the pistons on the normal calipers at the rear?
33mm based on when I asked although I wasn't model specific.
http://www.e30zone.net/modules.php?name ... light=rear
GeoffBob
Forced Induction Specialist
Mon Nov 09, 2009 10:02 am
32mm I think Rich ???
M3 rear calipers, BTW, are 35mm.
k13, see my "E30 Front Brake Upgrade" thread here. Should have some useful info for you. Fits under 15" rims but is full-on DIY.
Jonsku
Mon Nov 09, 2009 1:19 pm
You can get some idea of different BBK's on www.300mm.de ;)
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
Dave_M3
Tue Nov 10, 2009 1:33 am
Yep, I'm in love with the Porsche Boxter brake upgrade...
328 on the front and 294 on the back would be tasty!!!
GeoffBob
Tue Nov 10, 2009 8:46 am
Dave_M3 wrote:Yep, I'm in love with the Porsche Boxter brake upgrade...
Write it up Dave, like I did mine. Share some of that love :D
Dave_M3
Tue Nov 10, 2009 4:46 pm
Yep, will do once I find a cheap set of Boxter S calipers and apropriate discs.
