reseting service light(I know its been askeda thousand times
rvrboy
Sat Jun 20, 2009 5:07 am
Hi, where can I get a picture of the pins to use for my Pre facelift e30.
Cheers Gerry
poolnoodle
Sat Jun 20, 2009 9:12 am
My local BMW garage will reset mine for nix but I have been going there for many years and had to ask nicely
rvrboy
Sat Jun 20, 2009 11:05 am
Thanks for the reply Willnz, Will get it done tomrrow
Cheers Gerry NZ
Sat Jun 20, 2009 2:04 pm
The pin numbers are marked on the socket if you look carefully. The reset pin is number 7 in both types of socket, and the other pin is just an earth.
7 is easy to find on the later socket - it's the one straight in front of 'pacman's' mouth.
I usually use an earth somewhere else (rear bonnet catch bracket is my favourite), because it halves the number of pins in the socket I have to identify, and my test lead I use for the purpose has a croc clip on one end.
e301988325i
Sat Jun 20, 2009 2:40 pm
is that the inspection light and the little clock too for brake fluid?
I said:
e30topless said:
lock the wife in there
Sat Jun 20, 2009 2:58 pm
All are reset by earthing pin 7 for different lengths of time.
pac1982
Sat Jun 20, 2009 3:10 pm
i did this on mine with help from the above peeps, but it only did the inspection light is there a way to do the oil lights as well?
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
Sat Jun 20, 2009 3:19 pm
Brianmoooore wrote:All are reset by earthing pin 7 for different lengths of time.
transatlantic0207
Sun Jun 21, 2009 3:32 am
do it with a paperclip be happy you used an item that costs less than a penny over a tool that cost $100+ or even worse paying a some tire changer an hour clock time at the stealership!
just bend the paperclip and stick the ends in the two hole #7 to reset and #19 the ground and turn the key to the second position...leave the paperclip in for i think 5 seconds and the oil is reset and 10 seconds will reset the service light
have fun and i'll come get my pint in september!
'I-tye' Euro-spec 1986 325i 2dr 2.5l has been wrecked...the replacement is a US-spec 1987 325is
The_Diddler
Love it up the more door !
Sun Jul 12, 2009 10:45 pm
just done this with my new service board, oil and inspection illuminated, now 5 green light and all is good, was fully serviced about 150 miles ago
Thanks guys for the info :D :D
Sun Oct 25, 2009 1:00 pm
Just done this following the service work I did on the car Yesterday :D
**BANNED**
Sun Oct 25, 2009 2:02 pm
I do not trust myself with bits of wire,I bought the proper tool about 4 years back for less than £15!
Youth is wasted on the young.
penton08
Sun Oct 25, 2009 2:19 pm
the proper tool is now less than a tenner from gsf.
transatlantic0207
Sun Oct 25, 2009 2:24 pm
a paperclip is less than a penny
Sun Oct 25, 2009 3:37 pm
penton08 wrote:the proper tool is now less than a tenner from gsf.
And can only be used for one thing! My piece of wire with a croc clip on each end has dozens of uses.
Sun Oct 25, 2009 3:48 pm
I can confirm that the paperclip method works :thumb:
Ollie_bwoii
Sun Oct 25, 2009 3:49 pm
I reset my lights, but after a day the inspection light came back on! :cry:
asmith88
Sun Oct 25, 2009 4:30 pm
a couple of bits of wire do the trick, an inline fuse woudnt hurt either :)
1990 brilliant red 318 is
