Does the 318is have a rev limiter???
Dan318-is
Post Tue Aug 23, 2005 12:16 am
AS above???
smithy318i
Post Tue Aug 23, 2005 12:24 am
I assume so...
Put your foot on the gas in neutral (at normal operating temperature) and see!
I found mine at 6250 ish
TheDutch
Post Tue Aug 23, 2005 10:53 am
Yes, it's about 6800rpm I think. You shouldn't have trouble finding it if you keep your foot down... :o
Edit.. 6800-ish with a chip!
Dan318-is
Post Tue Aug 23, 2005 10:56 am
super :lol:
Davenotouring
Post Tue Aug 23, 2005 11:04 am
I would do it in second, while driving along, rather than in neutral where there is no load on the engine.
Or hit the limiter in fifth like I did on Sunday! :oops:
BMW 328i Cab - Daily Slag
tourerti
Post Tue Aug 23, 2005 12:47 pm
If you rev the engine to the maximum limit stationary you will destroy the engine quickly as there is no counterballence to the engine from the prop.
CaesarBob
Post Tue Aug 23, 2005 12:57 pm
Definitely advisable to try that under load in 2nd rather than free revving.
Not sure what the actual figure is on mine but it's just into the red on the rev counter. About 6,500-6,600
'97 E36 B3 3.2 Touring - Alpina-Blau
'15 F32 420d M Sport Coupe - BMW - melbourne-metallic (Sold)
'11 E92 320d M Sport Coupe - BMW-saphirschwarz-metallic (Sold)
'99 E36 328iA SE "Shooting Brake" - BMW-titansilber-metallic (Sold)
'89 E30 325i
jaistanley
Post Tue Aug 23, 2005 1:00 pm
I hit the stupid thing all the time. Hit it in 4th sliding around a roundabout in daventry the other day. Wasn't best pleased.
Jai
Dan318-is
Post Tue Aug 23, 2005 1:06 pm
:lol: cheers lads il try it when my ECU is back in
tourerti
Post Tue Aug 23, 2005 2:12 pm
Is your name dan by any chance.
Hyperion
Post Tue Aug 23, 2005 2:36 pm
just one silly question. will it "hurt" your engine if you keep hitting the limiter, considering the age of our cars engines. I only hit my limiter once in 2nd before.
jaistanley
Post Tue Aug 23, 2005 3:44 pm
Well you have to be revving the nuts off it which is the killer of all engines! Friction, and therefore wear is proportional to the square of engine speed as is the energy in each piston at TDC..
Basically more revs = more likely to break (we knew that!)
Spose when you hit the limiter you introduce a step-change in power. It's these high transients that break stuff. The limiter on my 318is seems quite 'soft' so it's not too bad.
Is it a fuel cut or ignition cut limiter?
The stroke on the M42 engine is very short - hence the free revving nature. To hazard a guess I'd say unless the con-rod bolts or gudgeon pin are pig weak, a limiter of 6K (ish) protects you way more than enough..If I'm wrong I'm gonna be doing that engine swap sooner than later :lol:
Jai
Blackie_No1
Post Tue Aug 23, 2005 9:40 pm
yea they do, i found mine by accident one night when racing a mate in a megane 1.6 16v and passing him!! LOL! :lol:
325i sport replica
www.Teamlsm.com
Dan318-is
Post Wed Aug 24, 2005 12:00 am
good to hear lol
yeah my name is dan how comes?
Blackie_No1
Post Wed Aug 24, 2005 1:04 am
i fink he is tryin to be funny, with ref to ur sig mate?
325i sport replica
www.Teamlsm.com
tourerti
Post Wed Aug 24, 2005 8:28 am
I didnt read the sig sorry, have you had your post today as I sent you something monday for jay.
astondg
Post Wed Aug 24, 2005 10:01 am
I used to hit the 6500rpm limiter a lot in my 323i when racing because it was still pulling ok and I didn't realise. Aslo with the gear ratios not right for most of the tracks I go to I often ran out of revs in the middle of a corner. Since I got the standalone EMS fitted with the soft cutout at about 6550rpm and hard at 6600rpm I haven't hit either. The power band seems to have changed and it doesn't pull as hard up high anymore, I think I change around 6000rpm now.
Aston
BMW E30 323i with some stuff
1:05.17 @ Queensland Raceway Sprint track
1:10.09 @ Queensland Raceway Clubman track
1:21.67 @ Morgan Park Raceway
jaistanley
Post Wed Aug 24, 2005 10:32 am
I think people instinctively change when they 'feel' it's right. That's why I hit my 318is limiter so often and I haven't in previous cars. I recon BMW were too conservative with it and put it right where the engine is making torque and therefore right where it's least bloody needed! :roll:
Jai
Demlotcrew
Post Wed Aug 24, 2005 10:51 am
6200
Dan318-is
Post Wed Aug 24, 2005 11:21 am
toureti ye got Chip today :lol: unbeliably fast delivary mate
OBC from KarlP also arrived looks impossible to fit tho
tourerti
Post Wed Aug 24, 2005 12:00 pm
318-is wrote:toureti ye got Chip today :lol: unbeliably fast delivary mate
Let me know how ya get on with it,
Dan318-is
Post Wed Aug 24, 2005 12:08 pm
will do fella
