2.5 inlet and injectors on an M20B20
Rosco320i
Post Sat Oct 03, 2009 11:41 pm
Hi all, i've heard somewhere that there are gains to be had if I put the inlet, injectors and throttle body off a 2.5, I can gain some performance.
Is this true??
Wouldn't I need to remap too?
bmw1066
Post Thu Oct 08, 2009 1:41 pm
u can but you will need to open the head up a little. as the inlets are smaller, easey job so I have been told. All this and a re-map will make a diffrence. :) also a good cold air induction kit work well.
Mark
BMW E23 735 1982 RESTO
BMW E34 V8 1994 SPORT KIT
BMW E30 320I TRACK AND RESTO TOY
RANGE ROVER CLASSIC
JEEP
Spelling and Gramer alway's very bag
AlpineAde
Post Fri Oct 09, 2009 3:55 pm
Rosco320i wrote:Hi all, i've heard somewhere that there are gains to be had if I put the inlet, injectors and throttle body off a 2.5, I can gain some performance.
Is this true??
The inlet manifold and throttle body is a popular swap out of the box. Once you start down the route of bigger injectors and other work you'll need to map for that.
Rosco320i
Post Sat Oct 10, 2009 1:34 pm
Nice one thanks for the info, I'll get on it.
As far as opening the head up, is this something I can do myself? can it be done with the head on the car?
Cheeers :D
AlpineAde
Post Sat Oct 10, 2009 2:29 pm
You mean porting the head?
That would be best left to the professionals. When you get the head reconditioned the shop will take care of that for you.
bmw1066
Post Tue Oct 13, 2009 10:59 am
You could also fit a 325 exhaust system, I'm fitting one so will let you know. :cool:
Mark
RANGE ROVER CLASSIC
JEEP
