325i sport wiring loom
sidewaysbm
Post Sun Aug 21, 2005 7:25 pm
hi, had a bit of a fire in the engine bay and was wondering would i need to replace the entire wiring loom in the car, or does the engine loom unplug from the rest of the loom? Also any ideas on what caused this? :(
Andy325i
Post Sun Aug 21, 2005 7:26 pm
The engine loom just plugs in at the bulkhead plug mate.
Where is the fire damage?
Andy
sidewaysbm
Post Sun Aug 21, 2005 7:36 pm
i am not exactly sure where it started, could it have been a loose wire? how much would a replacement engine loom cost?
Andy325i
Post Sun Aug 21, 2005 7:38 pm
Best to get one off a zoner (look in the parts for sale section) make sure you get the right one, there are 2 types, early and late (early has 2 rows of ecu pins, late has 3).
Should be no more than 30 pounds
Could be electrical or petrol etc?
Andy
sidewaysbm
Post Sun Aug 21, 2005 7:48 pm
will any late model do, or does it have to be a 325i loom?
A1BMW325iSport
Post Sun Aug 21, 2005 7:55 pm
i have an early 325i engine loom
sidewaysbm
Post Sun Aug 21, 2005 10:47 pm
sorry boss, my car is 1990. :(
Martinaston
Post Sun Aug 21, 2005 10:56 pm
Do you have the check control on the car ?
There is NO nucleus.
sidewaysbm
Post Sun Aug 21, 2005 11:04 pm
whats that? :?
Martinaston
Post Sun Aug 21, 2005 11:07 pm
The button and all the red lights above the rear view mirror, It tells you if any bulbs have failed or fluid levels are low.
sidewaysbm
Post Sun Aug 21, 2005 11:18 pm
dont have anything like that :(
Jos
Post Sun Aug 21, 2005 11:33 pm
The 2 engines I have taken out the engine loom plugs into the fuse box and the ECU multiway fits back through the firewall behind the dashboard on the right hand side. Provided the fire wasn't near the fusebox you should be able to replace just the engine loom. If the fusebox is gone too I think there is another big multiway behind the glovebox that you can disconnect to get the fusebox out.
The other issue is if you had a fire started from an electrical short you need to be careful that it hasn't fried any of the wiring in the car.
'94 e36 tree climber
A1BMW325iSport
Post Mon Aug 22, 2005 12:47 am
fusebox can`t be replaced its pretty much wired in, it would take less time to replace the whole loom
sidewaysbm
Post Mon Aug 22, 2005 2:34 pm
could this fire have harmed anything else?
A1BMW325iSport
Post Mon Aug 22, 2005 2:42 pm
i would have a good look at the wiring that comes through the bulhead behind glovebox,
i had this on my old 320i the wiring had melted from the engine bay to fusebox and about 6 inches through into area behing glovebox.
i replaced the whole loom
sidewaysbm
Post Mon Aug 22, 2005 3:57 pm
did you find out what the cause was?
A1BMW325iSport
Post Mon Aug 22, 2005 4:12 pm
no i bought the car cheap with electrical problems, but then it got worse and smoke came from the engine bay one done when i went to start it, after finding all the wires melted i replaced the entire loom
