update
Ant
- Retired Team Member
Well it would seem the sensor is functional then dude !
Hmm, I'd say the idle mix was waaaaaaaaaay off, whats the Emerald saying dude ?
Email FTW
lentec
- Boost Junkie
Cheers ant will pm some details
lentec
- Boost Junkie
Well looks like the heads gonna have to come off
Think i was a bit trigger happy with the drilling of the head!
Im getting no oil from the spraybar!!! i even ran it with the rocker cover off
dry as a bone
Ive drilled 4 too many holes on the exhaust side rockershaft to cam bearings
It also looks like my supercharger has sucked some crap in from somwhere
and made a mess of the roters
lentec
- Boost Junkie
Ive been advised that oilways can be plugged but i need to get the head off!
As anyone who has done this knows it aint fun!
Still ordered new gasket and bolts gonna pick em up this afternoon will hopefully be back on track by friday!
wish me luck
wish me luck
Turbo-Brown
- Boost Junkie
Oh weak! Sorry to hear that Len
What were the holes for?
lentec
- Boost Junkie
I used the 27 head and 25i camshaft as there is 4 extra berings i asumed both sides nedded drilling!
At the moment looking like a minor setback just a bit more work,sweat,skin needed!
Ant
sounds like some brass plugs are the order of the day Len.
Bad news on the S/C mate, WTF could have got through the filter and still caused damage
all in our stride eh chaps, you fellas coming to Lakesdie BTW ? be nice to meet in person
Email FTW
Turbo-Brown
- Boost Junkie
When's the Lakeside thing? Doubt I'll be ready before the end of september at this rate
Had to plead with the guy I buy metal from for him to send me a stick of ali. I'd designed the throttle bodies for the injectors to mount directly in the 25mm thk plate. However, I've thought better of that idea so I need to machine up some bosses to space the injectors from the head a bit.
Sadly, he's off for two weeks today so I'm hoping for a miracle!
e30_Turbo
- Boost Junkie
Turbo-Brown
- Boost Junkie
Sweet!
How much were the injectors?
Matt318i_droptop
Alex,Turbo-Brown wrote:Sweet!
They were about $230, but I got them from a guy in the states who had them spare, plus the LC-1.
Ant sourced his from ebay, same ones at about the same price too.
I take it you got the urge now?
Two of the green ones flow more than all six of the std ones, god knows what the fuel consumption is gonna be, ow well to late to worry about that now!
(ooops, wrong sign on
Turbo-Brown
- Boost Junkie
I've got some slightly bigger injectors from a Pug Mi16 which according the Emerald's little calculation should flow enough for about 300bhp on a 6cyl engine. Should be more than enough for my 260bhp aspirations anyway
Anyhoo, just got an e-mail from my mate to say that the material to make my silencer and air box has turned up so I'm gonna be a busy burger this weekend!
e30_Turbo
- Boost Junkie
Turbo-Brown
- Boost Junkie
I've got 10
Should be able to find something suitable out of that lot.
Karan
whack the spare 4 in the charge pipes somewhere...LOL
Andy335Touring
How much was the LC-1 ?
Ant
Brand new in the USA direct off innovate motorsports they are $200 including the software for datalogging etc.
purchase from diyautotune.com , reliable and fast service
Email FTW
Andy335Touring
Cheers Ant
Ant
The LC1 is the WB02 and a controller, the Emerald has a WB controller internally so you can save a few $$ Andy, I believe the senor alone can be had for $100
Email FTW
lentec
- Boost Junkie
Well its running again!
It was a lot of bloody hard work! i had some help tho! cheers andy!
http://lentec-e30.tripod.com/index15.htm
sounds a lot better now!
just need to remount the s/c it looks like the belt may have been jumping = less
boost and the skufs on the roters are from it standing for a while!
I didnt know the emeralds had a WBO2 controller!
on the subject of o2 sensors any luck ant?
Andy335Touring
Bonus !ant wrote:The LC1 is the WB02 and a controller, the Emerald has a WB controller internally so you can save a few $$ Andy, I believe the senor alone can be had for $100
I thought i needed the controller to interface with the Emerald.
So i could just get a WBO2 from some where in the UK and hook it up to the ECU ?
What i need though is a cheep lap top PC so i can make use of the data logging on the Emerald.
Turbo-Brown
- Boost Junkie
I was also under the impression that you needed some kind of controller for the WB on Emerald.
Might be worth check with them just to be sure?
Andy335Touring
I've got a cossie 24v coil pack to wire up as well and the manual doesn't say which pin outs to use with a wasted spark 6 cylinder set up so i'll ask about that as well.
I also want to know which resistors i need to use with the low impediance E28 M5 injectors that i want to use with my TB's.
Turbo-Brown
- Boost Junkie
Aah yeah, there's a different wiring diagram for the DIS 6 cyl. You lose some function or other (can't remember what) when you use a DIS coilpack for 6cyl operation
jmc330i
A mate of mine just bought a cheapish Lap Top from WoolworthsAndy335Touring wrote: What i need though is a cheep lap top PC so i can make use of the data logging on the Emerald.
I would assume its an offer all in their stores.
It cost him Ԛ£349 and seems a fair lap top - he got rid of all the pre-programed software like AOL and the cheap antivirus stuff etc, and it does everything he wanted. The only problem is that the CD drive is a separate unit connected via USB.
Not sure what specs you would need to run the stuff for Emerald, but it might be worth a look.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
e30_Turbo
- Boost Junkie
lentec
- Boost Junkie
andy: i had the same problem with the coil pack wiring if you look at the bottom of one of the pages (not in the manual!) they supply with the m3d it does say there!
hold on ill go look!
Andy335Touring
I've done that !fozzymonster wrote:
Only want a basic one, just for MS really, home PC looks a bit strange sat in the passenger seat
But no good for data logging though
James, thats well cheap ! So long as i can get the Emerald OS loaded on to it and it has the 9 pin connector for the serial cable i'm not bothered what else its got feature wise.
Is this the one ?
http://www.woolworths.co.uk/wwstore/pro ... op=details
I've got a mate with a lap top but it hasn't got the 9 pin connector on it
I am a bit scared of getting a second hand lap top incase it has problems i can't fix as i havn't a clue when it comes to lap tops.
Andy335Touring
Cheers dude that would be greatlentec wrote:andy: i had the same problem with the coil pack wiring if you look at the bottom of one of the pages (not in the manual!) they supply with the m3d it does say there!
lentec
- Boost Junkie
It says pin 4 main relay controll is also driver for third coil
the other two are as the manual says.
lentec
- Boost Junkie
If its got no serial port you need one of theese
http://secure.cbm.uk.com/google.php?id=CLTAR-NLUSB-0039
Ive came up with a way to get the cam rockers ect out with the head in place!!!!
Andy335Touring
Thanks for the info mate
That sounds a weird way to do it ?
The relay wants a constant - and the coil would shurly want a variable intermitant - to trigger it ?
Is yours wired this way ? Did you have to change any thing in the soft ware to change over to this set up ?
lentec
- Boost Junkie
Thats the way mines wired in!.
only told the software in the setup bit that it was six cylinder
Andy335Touring
Your a star mate !lentec wrote:If its got no serial port you need one of theese
I can borrow my mates lap top now
Andy335Touring
Thats cool mate, just seemed a little strange to me.lentec wrote:Thats the way mines wired in!.
So do you run the relay and the the third ignition circuit together from pin 4 ?
