I'm still pondering "scrap yard raid" options to stiffen up the IS a bit more.
Really I need to fit new dampers as a first move and then see what I think.
The author of "modern engine tuning" reckons that fitting the beefiest anti roll bars is the way to go with car suspension. So I was wondering if the 320 or 325 sport got bigger ARBs than the 318is.
Having said that, the IS is such a nice rounded package as standard I'm quite tempted to leave it alone.
ARB sizes.
Adammcf
As far as I know the 318is has the same ARB's as the 325 Sport. Not 100% sure though.
325 sport and 318iS have same suspension exactly. Get some inverted bilstein dampers they are the best.
Your not gonna find anything in a scrapyard to make your iS handle better, u need to buy new stuff
- Homo Hair
m3 anti roll bars..
the guy who is selling the m3 springs has some as well...
Templ8e30
All tourers have 20mm front ARB's as opposed to 18.5mm for the rest of the range. Not sure about the cabs though.
I have a 318is rear ARB and a 316i touring 20mm front ARB.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Richy325iTouring
arnt the tourings the same arb as the m3?
Martinaston
Would an E28 rear be the same shape?
There is NO nucleus.
Karan
325i sport and m3 arbs.... i have both and they appear to be the same diameter.... of course the front arrange,emt on the m3 is different cos of the droplinks attaching to the struts
jaistanley
Having them 'pick up' on the struts means there is a larger lever moment on the ARB.. In effect making it stiffer.. Why not weld on the tangs to take the M3 droplinks? I was gonna do this before I got my M3 running gear..
It's made my car loads faster sat there in the garden waiting for attention!
Jai
Jai
iKst
The simple way is to stick 2 ARBs together. Find another E30 ARB and then clip it together with the one you have on now with strong jubilee clips. Its cheap and it works good.
Jos
http://www.e30zone.co.uk/modules.php?na ... suspension
Thread from a while ago about suspension.
Eibach do a lovely ARB kit for the e30, but it ain't scrappy prices..
'94 e36 tree climber
tomstickland
Not if I can find thicker anti roll bars and springs.Your not gonna find anything in a scrapyard to make your iS handle better, u need to buy new stuff
I agree, with things like bushes and dampers then new is the way to go.
Widge
If you can weld and drill you could feasibly make ajustable ARBS like racing cars, and just stick with the size you like.
