building a lovely NA 325 m20
timsands
going to build a nice 325 engine up and wondered what would be the best parts and techniques for this.
thinking of:
cam, zaust manifold, chip, fuel pressure reg, lightened flywheel.
any thoughts, want a powerful high revving na engine
thinking of:
leeparkes
Stroke it to a 2.8
steve_k
+1 then do everything else on your listleeparkes wrote:Stroke it to a 2.8
leeparkes
here's one build thread
http://www.e30zone.net/modules.php?name ... sc&start=0
Or for less money throw an M50/M30 in there
goosiegander
- Zonegoose
2.8 M20 ftw!
chu346
goosiegander wrote:2.8 M20 ftw!
Turbo
GeoffBob
- Forced Induction Specialist
Simply follow the "Step-by-Step guide to Engine Blueprinting" by Rick Voegelin, published by Cartech (see http://www.cartechbooks.com) for pratical methods to increase performance of N/A engines for both road and race applications.timsands wrote:going to build a nice 325 engine up and wondered what would be the best parts and techniques for this.
thinking of:
Nothing wrong with a good N/A engine, and well worth doing it properly.
chu346
For the cost you might aswell go turbo.GeoffBob wrote:Nothing wrong with a good N/A engine, and well worth doing it properly.
e301988325i
uprated rockers!timsands wrote: want a powerful high revving na engine
I said:
e30topless said:
lock the wife in there
nickso
- Location: Go do that voodoo that you do so welllllllll!!
anyone tried the newman cams rockers? they seem good value but im not sure whats "uprated" about them.e301988325i wrote:uprated rockers!timsands wrote: want a powerful high revving na engine
'88 e30 328i M52 track bint.
BadDave
2.8 M20 with a turbochu346 wrote:goosiegander wrote:2.8 M20 ftw!![]()
Turbo
e301988325i
ebay item number 270215187635 £OUCH
I said:
BadDave
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 3D1&_rdc=1e301988325i wrote:ebay item number 270215187635 £OUCH
Looks like we'll have to enquire at Newman's to see what their rockers are good too. Especially as there less than 1/4 of that price.
- Homo Hair
24v swap is the best way round your rocker issues..
true, forget the pressure regulator you won't need it.
Some lighter conrods from the bmw parts bin, M50,M52. FLywheel, maybe some lighter slugs?
2.5's can really rev with a cam and lighter flywheel. They're a bit lethargic with the stock cam
e21Jason
the
newman rockers are steel not alloy and I am not sure how many sets the have as 2 years I got a deal from them for all there remaining stock of m20 rockers
jason
jason
ross_jsy
itb's?
toby
Skim the head to raise compression ratio.
Start off with the higher compression pistons.
Cam and complementary chip would make it revvy- even this bit costs a fair bit to do thoroughly.
Did you have a budget in mind?
I have a tech 1 flywheel if you are interested.
For what you have planned for the M20 donk, by the time you have finished with all of this, you'll be about 3 grand lighter.
Unless you are a M20 bufty and all up for originality or just want the challenge of rebuilding an engine yourself, it is difficult to look past doing a 24V swap as a more cost effective means of getting better power.
skimming heads to raise the CR isn't a good idea if your fitting a high lift cam imo. I don't think its a good idea at all personally
