Whats the ticking noise from engine
johnt0709
Anybody help what is the ticking noise likely to be on a 6cylinder - top end - runs great though - tappets? Any soloutions?
sam325is
Injectors.
Eddie25
Definatley most likely to be tappets mate. Even when set correctly they can still sound like a typewriter falling down a flight of stairs.
The 6 cylinder engines can suffer from Injector tick though but I've heard getting them ultra sonically cleaned can improve this.
sam325is
Correct!Eddie25 wrote:The 6 cylinder engines can suffer from Injector tick though but I've heard getting them ultra sonically cleaned can improve this.
johnt0709
Anyway to tell if it is rappers or injectors?
sihooker
I've heard that a ticking noise on M20's can also be due to a leaking exhaust manifold...
allstar_07
I've read the test to do is hold the engine at 4k rpm and turn the ignition off. if the noise stops straight away rather then dying down with the revs it's the injectors. This is because they stop as soon as the elec supply is cut off.johnt0709 wrote:Anyway to tell if it is rappers or injectors?
Hope that helps.
johnt0709
Allstar thanks I'll give that a go - makes sense
allstar_07
How do you fix a noisey rocker then Will?
I adjusted my tappets but that didn't seem to make much difference - well at idle it does but the engine still makes a loud noise when revved. I'm assuming it's the injectors but I haven't done the check above yet.
johnt0709
Technical comment here - It is def ticking and not a knocking - nothing sinister will try at the weekend the 4000rpm/ignition off test and update.
ChemicalAl
If its the injectors what are the options (other than ultrasonic cleaning)?
1987 E28 528i Diamond Black 74k
1986 E28 525e Saturn Blau 72k
1988 E28 525i 56k
1987 E28 525e 51k
1991 E32 730i SE Granite Silber 75k
1988 E30 316 Black 81k
1992 E30 318i Touring Diamond Black 43k
1990 E30 325i Touring Alpine White 2 65k
1986 E30
1988 E28 525i 56k
1987 E28 525e 51k
1986 E30
SteSE
- Heading for the Naughty Room
fit new ones
ChemicalAl
Thought so - how much for the parts and approx cost of labour?
1988 E28 525i 56k
1987 E28 525e 51k
1986 E30
1988 E28 525i 56k
1987 E28 525e 51k
1986 E30
bilun777
If it's just ticking at idle and drives O.K. drive and enjoy. Simplez
If it aint broke don't fix it!
SteSE
Not sure how much new ones cost, the ticking is good - at least you know there working plus i thought the machine gun noise is a characteristic of the m20??
Have i been mis-sold...
GT-UK
i got a really sweet chromie last week, loads of dealer history,macahnincally spot on
i actually know know after years of owning e30s what the m20 engine is meant to sound like,
a silky smooth almost silent engine with a low gurgle from the tail pipe,
rather than a skeleton having a w**K in a biscuit tin
changes on a weekley basis
poolnoodle
+1sihooker wrote:I've heard that a ticking noise on M20's can also be due to a leaking exhaust manifold...
I have this issue after eliminating tappets and injectors. Simple fix but arse of a job. Hence not done
johnt0709
You see this is what im looking for - is this achievable? Or not worth the effort?GT-UK wrote:i got a really sweet chromie last week, loads of dealer history,macahnincally spot on
