Whats the ticking noise from engine
Definatley most likely to be tappets mate. Even when set correctly they can still sound like a typewriter falling down a flight of stairs.
The 6 cylinder engines can suffer from Injector tick though but I've heard getting them ultra sonically cleaned can improve this.
- allstar_07
I've read the test to do is hold the engine at 4k rpm and turn the ignition off. if the noise stops straight away rather then dying down with the revs it's the injectors. This is because they stop as soon as the elec supply is cut off.johnt0709 wrote:Anyway to tell if it is rappers or injectors?
Hope that helps.
- allstar_07
How do you fix a noisey rocker then Will?
I adjusted my tappets but that didn't seem to make much difference - well at idle it does but the engine still makes a loud noise when revved. I'm assuming it's the injectors but I haven't done the check above yet.
- ChemicalAl
If its the injectors what are the options (other than ultrasonic cleaning)?
1987 E28 528i Diamond Black 74k
1986 E28 525e Saturn Blau 72k
1988 E28 525i 56k
1987 E28 525e 51k
1991 E32 730i SE Granite Silber 75k
1988 E30 316 Black 81k
1992 E30 318i Touring Diamond Black 43k
1990 E30 325i Touring Alpine White 2 65k
1986 E30
1988 E28 525i 56k
1987 E28 525e 51k
1986 E30
- ChemicalAl
Thought so - how much for the parts and approx cost of labour?
1988 E28 525i 56k
1987 E28 525e 51k
1986 E30
1988 E28 525i 56k
1987 E28 525e 51k
1986 E30
i got a really sweet chromie last week, loads of dealer history,macahnincally spot on
i actually know know after years of owning e30s what the m20 engine is meant to sound like,
a silky smooth almost silent engine with a low gurgle from the tail pipe,
rather than a skeleton having a w**K in a biscuit tin
changes on a weekley basis
poolnoodle
+1sihooker wrote:I've heard that a ticking noise on M20's can also be due to a leaking exhaust manifold...
I have this issue after eliminating tappets and injectors. Simple fix but arse of a job. Hence not done
You see this is what im looking for - is this achievable? Or not worth the effort?GT-UK wrote:i got a really sweet chromie last week, loads of dealer history,macahnincally spot on
