Post
Sat Sep 19, 2009 6:04 pm
First things first - what model is the naka h/u that you're fitting???
Some of them can be a bastard!!!!!!
As cliffy has said above, best thing you can do if you're struggling is to grab a meter and test the wires you have in the car.
To get some action, you will need:
1. A constant live connected to the yellow wire on the h/u,
2. A switched live (comes on with the ignition) connected to the red wire on the h/u,
3. An earth connected to the black wire on the h/u.
I think the yellow and red are the right way round - if not, switch them, or put them both constant live (just means the stereo won't turn off with the ignition!).
From that, you should get something, lights, etc!! Then you can hook up speakers, rca's, whatever!!
Also, check all the fuses again (12 & 21 I think) when those three are connected up. Some of them blow really easily, no matter how careful you are!! Really, should be advising you to disconnect the battery before playing with these connections!!
You may also have an orange lead coming from the h/u - that is for the illuminations!! Pretty sure there is no wire for this on the E30, but you could take a feed from the clock or something if you really want - but test it first!! All it does is dim the display when you turn the cars lights on!
I have played with a lot of stereos and have never found one that needs anything else connected to light up!!
Where did you buy it from?? I'm guessing it wasn't a high street store!!! If it was, they'd help you out!!
You could always nip into a local place and ask them to check if it works for you!!
