Wiring Nakamichi
Post Mon Sep 14, 2009 6:01 pm
Should I cut from here?
Whole loom. It has fuses. All original.
Want to connect to this ISO.
Any does anybody know which wires are which?
Post Tue Sep 15, 2009 4:02 pm
anyone?
Post Tue Sep 15, 2009 5:33 pm
I've connected the red of the car to the yellow of ISO and black to black and in wont power on.
Post Tue Sep 15, 2009 5:45 pm
Blitz, looking at your plug the car only has front speakers?
red/black are power supplies, the orange is the memory i think and blue is the aerial, the double wires are for the speakers.
hth
Post Tue Sep 15, 2009 6:13 pm
It has 4 speakers. On the ISO plug I've red both red and yellow wires but still no power going to the headunit. Could it be something to do with the spade connections on the red and yellow wires?
Post Tue Sep 15, 2009 6:50 pm
Have you checked on your car that the E30 stereo loom is plugged in on the accesory point in the glove box?
did the 4 speakers work?
You want to hardwire that picture of your ISO thing to the E30 stereo loom, it should go then. Red with red, black with black for the power
Post Tue Sep 15, 2009 6:58 pm
The old head unit works when I connected red to red and black to black.
The 4 speakers did work before.
Post Tue Sep 15, 2009 7:05 pm
Looks a mess, if i were nearer i could come and do it, but its hard to explain over the net
personally i would buy another ISO lead and cut it up and using block connectors wire it to the cars wireing, you are best to keep the naks wireloom intact
on mine ignition is red and permanent live yellow, brown or black earth, blue remote for aerial, and the speakers are the rest, although there is no speaker wiring behind mine as i have an amp, but thats pretty straight forward
Post Tue Sep 15, 2009 7:11 pm
The nak uses an ISO loom I have cut to use.
Post Tue Sep 15, 2009 7:18 pm
dont cut the nak one up, getting a replacement will be hard, fit a male ISO end into it and wire that the the car
Post Tue Sep 15, 2009 7:21 pm
Allready have. I thought is was just a standard ISO lead.
all ready cut :(
Post Tue Sep 15, 2009 7:22 pm
I'm an idiot. I've never used ISO leads before.
hennared323i
Post Tue Sep 15, 2009 7:31 pm
Have you pressed the reset button on the unit?
Post Tue Sep 15, 2009 7:43 pm
yes
hennared323i
Post Tue Sep 15, 2009 7:54 pm
Red and yellow on the Nak loom both need wiring to power, black to earth, blue(s) iirc are remote power on and arial start and the rest are speakers (8 of in 4 pairs)
I think red is permanent live (for memory etc) and yellow is switched live via the ignition.
The accessorie socket behind the glovebox has specific feeds for this.
Post Tue Sep 15, 2009 7:55 pm
You relise some radios wont power on without the Antenna :) , do you have both Permanent and ign lives connected.
I would cut all that crappy aftermarket wireing out as it probably confuses things
Post Tue Sep 15, 2009 7:56 pm
i thought it was the other way around? :)
Post Tue Sep 15, 2009 8:35 pm
Right I've disconnect the crap that was there.
Behind the glovebox
Right side of loom
Far left you see the red black wires
Found this. Its supposed to be the power from the battery.
Proper messed up.
Post Tue Sep 15, 2009 9:04 pm
Red - Ign
Yellow - Perm Live
Yellow/Black - Speaker 1
Yellow /Brown - Speaker 1
Blue / White - Speaker 2
Blue / Black(Brown??) - Speaker 2
Brown - Ground
Thats My Guess but i cannot make out some of the wires
Try Using one of them screwdrivers with the light in, (i Use one often enough and i dont know name) :o: Electrical Tester???? to Make sure you have the IGN live and Perm Batt Live
Also if you cannot find ground, use a bit of wire screwed to the metal bit at the top of the glove box :thumb:
6potpower
Post Tue Sep 15, 2009 9:11 pm
Or did you want the e30 side wiring diagram?
Post Tue Sep 15, 2009 9:32 pm
I connected the yellow wire of the car to the yellow of the Nak and it still does not work.
Post Tue Sep 15, 2009 9:45 pm
is the Aerial connected?
Post Tue Sep 15, 2009 10:02 pm
No
Post Tue Sep 15, 2009 10:05 pm
Connect it, i would bet thats the problem
Post Wed Sep 16, 2009 1:30 am
Still no worky.
hennared323i
Post Wed Sep 16, 2009 8:55 am
Is this a new unit?
Post Wed Sep 16, 2009 11:05 am
Yeah
hennared323i
Post Wed Sep 16, 2009 8:48 pm
Strange.
German Ebay?
Have you bench tested it i.e. red and yellow through a fuse on positive, black to negative etc?
6potpower
Post Wed Sep 16, 2009 10:35 pm
aint hard mani cud do it in 5 min
Post Wed Sep 16, 2009 11:40 pm
Fuse ok?
have you tested that the wires are both live?
Post Thu Sep 17, 2009 1:04 am
Fuse is fine. I have to look for my tester.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Sep 17, 2009 11:45 am
Blitz back to basics test the wires try ur old radio again etc start fresh :cool:
miniblob
Post Sat Sep 19, 2009 6:04 pm
First things first - what model is the naka h/u that you're fitting???
Some of them can be a bastard!!!!!!
As cliffy has said above, best thing you can do if you're struggling is to grab a meter and test the wires you have in the car.
To get some action, you will need:
1. A constant live connected to the yellow wire on the h/u,
2. A switched live (comes on with the ignition) connected to the red wire on the h/u,
3. An earth connected to the black wire on the h/u.
I think the yellow and red are the right way round - if not, switch them, or put them both constant live (just means the stereo won't turn off with the ignition!).
From that, you should get something, lights, etc!! Then you can hook up speakers, rca's, whatever!!
Also, check all the fuses again (12 & 21 I think) when those three are connected up. Some of them blow really easily, no matter how careful you are!! Really, should be advising you to disconnect the battery before playing with these connections!!
You may also have an orange lead coming from the h/u - that is for the illuminations!! Pretty sure there is no wire for this on the E30, but you could take a feed from the clock or something if you really want - but test it first!! All it does is dim the display when you turn the cars lights on!
I have played with a lot of stereos and have never found one that needs anything else connected to light up!!
Where did you buy it from?? I'm guessing it wasn't a high street store!!! If it was, they'd help you out!!
You could always nip into a local place and ask them to check if it works for you!!
327 Touring with bass!!!
Post Wed Oct 07, 2009 5:38 pm
Thanks, guys got a professional o fit it now its all working.
