Aswell as doing the change above i want to bore it out to a 2.7i also same applies is it a good idea and how much am i looking ball part figure.. Thanks alot people.
changing my 325i auto to manual ALSO Bore out to a 2,7. HELP
Hi guys and girls as above states i want to change my 325i 1991 H-reg to a manual is this a good idea..? also how much and who can do it on this site..?
You might have trouble boring out to 2.7
Have you read the sticky? http://www.e30zone.net/modules.php?name ... ic&t=89665
Why don't you tell us where you live, maybe someone can help you with some where to get the work done then.
StuBeeDoo
You don't bore for 2.7, you need a longer throw crank.
About a year ago I was pricing-up a full rebuild - done properly with the bores honed, new piston rings, all the gaskets, check the big ends and mains, new shells, head skimmed, etc, etc. I gave-up when it came to over £1k. As an example, piston rings were £25+VAT per pot IIRC, so there's over £170 for starters.
Oh ok i thought they were simply bored out but this dont seem the case.. ooops, I live in leamington spa, What do you guys think about the change from auto to manual..? any long term effects in a bad way or is it nothing to worry about.? cheers
