What intake boot to use with M30 AFM
Stevin
Post Fri Aug 12, 2005 2:48 pm
So which boot should I use ?
I've heard that I can u an E36 325i one... but I haven't seen one to compare.
Widge
Post Fri Aug 12, 2005 3:12 pm
Are you running an M30 AFM on an M20? I'm just interested to hear if it is a plug and play upgrade, and if it gives any noticeable improvements.
As for the boot I'm afraid I can't help you buddy.
I think Fozzy moster has done somp experimenting with various AFM's.
Stevin
Post Fri Aug 12, 2005 3:26 pm
Well the one I got is plug and play.
Although I do know that the earlier models, u would need to modify the AFM, I think u had to use the M20 AFM Circuit board or something... None of my friends have ever had that problem with the electronics.
Widge
Post Fri Aug 12, 2005 4:23 pm
Ah wicked mate, I assume it is bigger than the M20 one. I'm goignt o need a bigger one when I run ITB's on my project 2.7 - cos I'm goingt o run it motornic to start with.
M5pilot
Post Fri Aug 12, 2005 5:56 pm
Your wasting your time with the M30 AFM.
Widge
Post Fri Aug 12, 2005 6:02 pm
Ok fair enough, why?
Jos
Post Fri Aug 12, 2005 6:26 pm
Still quite restrictive, I imagine M5Pilot is going to suggest MAF or some other fancy system
'94 e36 tree climber
Widge
Post Fri Aug 12, 2005 6:27 pm
Well exactly, I'm talking Ԛ£5 from the scrappy mods rather than Ԛ£500 complete systems. Howabout an afm from a hmmm 5ltr V12 :lol:
Shinobi1
Post Sun Aug 14, 2005 7:47 pm
Hi sorry its a bit late but dont get to my pc that often ! you can use a stock one if you warm up the end in hot water or with a hair dryer ,it will
go over the bigger afm ,i know coz i did it with mine !
all the best paul
Emotechnik
Post Sun Aug 14, 2005 8:12 pm
Widge wrote:Well exactly, I'm talking Ԛ£5 from the scrappy mods rather than Ԛ£500 complete systems. Howabout an afm from a hmmm 5ltr V12 :lol:
:mad: 5ltr V12 don't have AFM they have AMM
Widge
Post Sun Aug 14, 2005 8:35 pm
WTF is an AMM when it's at home????
Wait a sec.....Air Mass Meter? Twass just trying to illustrate the point.
not that my scrappy has many 850/750's in at the mo :lol:
Stevin
Post Mon Aug 15, 2005 12:06 pm
Hmm, well I tried heating it in water, and with my sisters hairdryer :D , and neither worked, so I got my thinking cap on, and decieded to get myself a M50 328i one, gonna go and fetch it 2day, cause I know it's bigger... lets see if that works.
E30Adam
Post Mon Aug 15, 2005 5:03 pm
DO NOT BOTHER WITH AN M30 AFM.
If you're running an M20 then this is a total waste of time and infact a loss of power.
I have experimented with this on a rolling road and have the graphs to prove it. The M30 AFM lost me 11bhp. THe car is so much better with an M20 AFM. Stick with the stock item.
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
Widge
Post Mon Aug 15, 2005 5:15 pm
Do you think that the M20 AFM will not be a little restrictive on a ITB'd 2.7 Adam? What other options are there without going down the MAF route yet :cry: Other wise I totally take your word for it, it's like the induction kits that don't work :lol:
E30Adam
Post Mon Aug 15, 2005 5:20 pm
Widge wrote:Do you think that the M20 AFM will not be a little restrictive on a ITB'd 2.7 Adam? What other options are there without going down the MAF route yet :cry: Other wise I totally take your word for it, it's like the induction kits that don't work :lol:
Dunno mate but I'd try and ditch the dated mechanical flap design of the AFM for something better, this is one of the major downfalls of the M20's stock setup.
Ant
Retired Team Member
Retired Team Member
Post Mon Aug 15, 2005 5:33 pm
One word.........................
Megasquirt!
no MAF/AFM wrongness, uses TPS and MAP for fuelling, can use the motronic ECU to look after the ignition still, makes it cheap, simple and very cost effective :wink:
under Ԛ£200 fitted and running, I have a base map if you need one too, will need a tweak but will run straight out the box
Shinobi1
Post Mon Aug 15, 2005 7:21 pm
E30Adam wrote:DO NOT BOTHER WITH AN M30 AFM.
didnt gareth make an extra 8 bhp on his 2.5 ?
Ant
Retired Team Member
Retired Team Member
Post Mon Aug 15, 2005 7:24 pm
He did indeed M8.
those that say the M30 aint worth it.... remember the SA evo sports with the 2.7... yep 027( M30) AFM fitted , good enough for them, good enough for you lot :lol:
same unit also used on the M3s , it takes some time to get it right, but when you get there, you'll not go back
Widge
Post Mon Aug 15, 2005 8:53 pm
OK i will probably go mega squirt in the end but to keep the staring costs down, I'll be using the AFM. So using an M30 AFM which one is best aand how do you "get it right" exactly?
